- Jan 9, 2022
- 14
What I thought was rust is factory primer. The picture shows the area I was talking about. This is typical around the outside of the body, doors fenders ect..
(HISTORY)This Bronco has had plenty outside storage of sunshine in the High Desert of California. I'm pretty lucky that it has minimal rust damage. Its a 1968. Purchased in 1970. Been in family since.
I have a sand blaster. Worked great on the frame restore. I am aware of the warping issues associated with sand blasting. I also Sand blasted the under carriage and it worked nicely. I'm using 30 mesh Industrial sand that is basically silica sand. ( Yes I use the proper PPE.) This is when I realized it has a factory dipped red oxide(?) dipped primer. You can see the runs.
ATTACHED: Picture of area that I sanded with 320 Grit.
QUESTION: I want to to prime and paint and do body work myself. Should I Hand sand or Sand Blast to bare metal?
