Electric fuel pump wiring
Steve83
That way the inertia sw only sees the current needed to activate the relay, not the pump.
Then it can't do its job. That would be like putting the power fuse in the relay feed instead of in the pump circuit. What if the relay sticks? What if the relay is mechanically jammed by the impact? What if the relay is miswired, or its trigger circuit becomes energized by a short that occurs during the collision?
The inertia switch is a failsafe mechanism, but only if it's wired the way Ford wired it. That's how the diagram shows it.
What kind of amp inline fuse would I need for the relay? Is 15 Ok?
If the wire is sized as the diagram shows, and the fuel pump(s) draws less than 15A.
.94 OR
Willamette Valley, OR
I have the FiTech 400 and had a fuel commander installed. The FCC uses a variable input signal to help control fuel pressure.
I am installing a 23 gallon tank with a high pressure pump installed and am planning to use an electric pump to transfer fuel out of the side tank to the rear. I'll switch that separate, but I'm thinking I would want to pull juice for that pump after the inertia switch just like the rear high pressure pump.
Any reason to use the provided electric wires for the FCC to control the rear pump, or just run it full 12V and let it burp the pressure off in the throttle body into the return lines?
ntsqd
heratic car camper
Upper SoKA
You've paid for electronic pressure control, seems like a waste to not use it.
That said, I prefer to circulate the fuel and for rigs that will see slow work in hot locations to take a page from GM's DuraMax page and put a cooler on the return line.
I was not aware that FiTech controlled any pumps in this way. Are you using an original style FCC, or the newer replacement?
Guess I'll have to read up on it, because I thought it was a simple internal pressure regulated valve that simply dumped excess fuel back into the FCC reservoir as the correct pressure was achieved. Then working pressure for the injectors was regulated at the throttle body's internal regulator.
So you'd be running three pumps off of the inertia switch? Or are you getting rid of the FCC altogether? Sounds like you're keeping it, but that would not really make sense, so can we assume you're tossing out the FCC in favor of the new in-tank pump?
I'm not sure if the switch has a load limit, but I'd check into that before running two, or especially three pumps.
Of course, even with the FCC intact only two would be running at a time normally, but in case you decided to transfer fuel while driving that would add the additional pump.
Otherwise yes, I would agree that any pump should be powered through the Inertia Switch for safety. That includes the FCC because it will always have fuel to pump out for at least a little bit after any other pumps are killed by the switch.
Again, depends on the load. If you are going to run both high pressure pumps through the FiTech system I would check that FiTech says it's ok to do so.
If you mean that the wires will be left over after you remove the FCC, then they would likely be good wires to re-use so you don't have to add more.
If they do indeed pulse on command from the computer to limit pressure, then I would NOT use them.
But again, I'm thinking that the 400 does not have that capability and only uses a basic pressure regulator to control what the injectors have to work with. Using a standard return line from the throttle body (of FCC) as recommended would enhance the performance of the system.
Are you currently running a return from the FCC?
Sorry if I misunderstood what you were planning. Just to be clear then, are you having trouble with the FCC? Are you planning to run just the single in-tank pump instead? Do you have, or will you be installing a return line?
.94 OR
Paul,
Hard to keep it straight in my head too since I work on it some drive it a couple times a year then park it for the winter.
FCC Gen1 is getting pulled. The system has left me along side the road too many times. The stock rear tank was rotting itself out so a new tank and lines are going in. I had a return "vent" line from the FCC but will be installing a new line from the bypass at the throttle body back to the pump in the tank. My understanding was the fuel control of the Fitech could regulate the output of the pump in the FCC but maybe I was mistaken. I will likely run full 12V off a relay since it should provide roughly the pressure needed at the TB and then have the return line to accommodate excess, which should also help keep the fuel cooler than what I had before.
The transfer pumps I'm spec'ing out don't look like they pull too much amperage (under 1 amp) and with just a flow of fuel I have a hard time picturing it overloading a circuit to move some fuel without a significant resistance such as a needle valve capping flow.
Agree. Probably not an issue.
I just cringe anytime we make changes and then find out there was some bit of programming or circuitry in the EFI that was not compatible!
Sounds like you've got it covered.
Does FiTech recommend using their fuel pump wire(s) to control a relay, or to power the pump directly?
I like relays for stuff like this, but if it's already handled from a built-in relay, being able to run it direct will save some wiring and remove one additional failure point.
But whatever you end up doing, the new in-tank setup should be great. Anything's gotta' be better than being stranded!
.94 OR
Any magic to where the fuel pump safety switch can be mounted?
Sounds like most cases it is inside the cabin on a kick panel.
Any reason it couldn't go on the inner fender under the hood, say in front of the fresh air duct on the passenger side?
Steve83
The magic is that it can't be where the metal vibrates - it needs to be a VERY rigid area of the body, like near several bends, welds, and/or corners. Not out in the middle of a big flat area that oil-cans easily.
.94 OR
Thanks for the link.
I have a fuel safety shut off switch that I will be mounting to the passenger kick panel for power to both the low pressure transfer pump and the high pressure EFI tank mounted pump.
My transfer pump is mounted above the frame and has a pressure switch to cut off when the pressure gets low as in a low fuel condition. I printed a mount to go under the dash to hold my air compressor and rear locker switch so I incorporated two switches for the transfer pump. One is an on/off that powers the pump, the other is a momentary on to prime the pump. Both are illuminated when the pump is active. Ideally, turn the switch on, no light, depress the primer button and both lights should come on, then once pressure is built up, release the primer switch and the lights should stay on until the transfer is complete, once done, the lights and the pump shut off. Pump picture is without the heat shield in place for easy viewing
