Electrical problems.
BRONCONY
North Eastern, NY
My 74 got some electrical problems going on. Haven't posted in a while but have been around. The problem is when you turn the key the battery goes to half power and nothing works. Walked over to the battery and air was hissing out the cap and it STUNK! Ripped it out and jumped it off the f150 and it was fine. So it's the battery. But what would cause that to happen. Bad connection? Short? It all started happing when I lost my blinkers. Relays are good but only the hazards work. Any ideas?
Viperwolf1
electron whisperer
Could just be a bad battery. Have it tested.
Turn signals could be bad fuse, bad flasher (there are 2), or even bad switch.
BRONCONY
BRONCONY
North Eastern, NY
True. Gona look in to it more. Looks like a bad battery going to get a new one this weekend. Pulled all the fuses and looked ok. The hazard flasher works and if you test the blinker flasher connector in the on positions (left or right) it shows volts.
When you say the battery went to half power, do you mean you went out and it actually measured 6v after only turning the key on? Or to START?
Where did you measure the power? At the battery post, or starter relay end of the positive cable?
Just for giggles, reach down behind the ammeter and find the bullet-connector in the large Black wire (might have a yellow stripe). Pull it apart and inspect for corrosion or looseness or any other fault. Other than the battery cables, this is (usually) the only thing that can kill the power to everything.
If it looks ok, put it back together and make sure it's a good tight connection.
If the cable, the positive cable sounds bad. When I had a bad cable, it would click when I hit START, but would instantly die and so would everything else. No more clicky no more starty.
But if you measured it at the post, I'd say bad battery. I can't think of anything on the truck short of a fully stuck or shorted starter, that could draw a battery down that far that quickly. During a normal start, the battery might read 10v or so, but not 6.
Have you connected another battery to it to see what happens?
Firs thing I'd do is at least turn the engine over by hand to make sure it's not frozen up. I doubt it is, but you never know, and that would certainly put the hurt on a starter.
How old are the cables? Check them for tightness and cleanliness, but if they're more than just a few years old (and even if they aren't) a new set of three 4ga or 2ga battery and starter cables definitely qualifies as cheap insurance.
I don't know what would make a battery boil like you described, but if a cable was shorted you'd see and hopefully smell it from it's melting. Be easy to find that kind of fault in a quick inspection.
Good luck. Probably a battery. Not the end of the world, and I can't see how anything to do with the turn signals or any of the related circuits could do this. If so, half of your wiring harness would have melted with it.
BRONCONY
BRONCONY
North Eastern, NY
Thanks for the respons. Motor runs great. Here's what happened, we went out on a long cruise and when we got back the turn signals would not work. After the weekend ii Tryed to start it went and turnd the key the brake light came on bright and normal (haven't bothered to reset it.) but when a went to start I herd a very faint buz a quick one then turn key nothing nothing nothing and brake light was barely noticeable. We have a horn wired to the fuse box so if that got power then it would work with the key on. Hit it and it was faint for 5 hits then it came in fine. All the lights worked and it fired right up. Oddest thing ever. Went for a few more rides before my tricks to get it started wouldn't work any more. Turn key brake light bright hit start no go and brake light very dim. Getting a new battery this weekend and going to look at the wires. It started fine when jumped off the f150. I'm thinking it was just the battery but we'll find out. And turn signals. Not a clue. Thanks guys!
BRONCONY
BRONCONY
North Eastern, NY
Ok. The battery was good from the test that advanced did. Also replaced the starter selinoid and it still does it. Going to take off all the wires pos neg and starter wire and replace those. When you turn the key the selinoid buzzes really quick then kills all power. You have to disconnect the batt to get power back. With out the wires on the battery and the jumper wires connected to the running f150 it turns over slower but dose fire and fun. It must be those wires. Let you guys know after we replace the wires.
Nice result! Makes a difference, don't it?;D
Now, on to the next project!
