tbratz
- May 29, 2006
- 128
I have an issue with the electrical system that started on my 69' a while back. It seems that my voltage fluctuates constantly by several volts. If you watch the amp meter it bounces around and when I turn the lights on they flare. It seems that when this occured years back I replaced the voltage regulator and it cured the problem. I have replaced it this time and it still does it. I replaced the regulator with a factory motorcraft part, so it isn't some off brand. I have cleaned and tried all the gounds, connections at the regulator, even tried two different alternators and it still does it. When you put a volt meter to the system the voltage reading will actually jump up and down by several volts. It is really becoming annoying and not to mention embarrassing sitting behind someone at night as my lights flare at them! Any suggestions or ideas I would appreciate it.
