Will an Electronic flasher work with L.E.D lights?
The Mechanical Flashers works on resisitence and the LED draw so little amps that the Mechanical flashers don't fire.
no, i tried it and it kept blowing fuses. there is however a no load flasher from hotronics. i installed one in mine and it works very well. they run about $35.00 and the phone number to get one is 714-971-8543. model #PG3. the only thing you need to be sure of is the flasher is marked "in" and "out". if the power coming in is not going to the terminal marked "in" then it will not flash. i had to reverse mine in my plug.
