Eliminating PCV
ilovemaui
Pacific Moist West
I was reading on one of the Mustang sites about a way to eliminate the pcv valve on an EFI motor. They capped off the vacuum on the valve cover and the throttle body then installed a ricer breather in place of the pcv valve. Has anyone tried this?
ilovemaui
ilovemaui
Pacific Moist West
I ran out of vacuum connections. What would happen if I teed it off the brake booster? There is no room betwwen the bottom of the intake and valve covers so I had to plug the holes. Eventually I'm planning to install hydroboost and it won't be an issue.
shamu
Lucky as the day is long.
Sachse,Tx
Here is BLING Quanity 4 (44 idi WEBER Carbs) On this set up there is not a single vacuum port for power brakes or a PCV. So my brother Darwin ran a single tube off the passenger side valve cover to vent the engine.
Please note if you run a Vertex magnito you need some serious ground wires.
And he is also running a 12v vacuum pump for the brakes. Don't forget to turn the switch on.
No problems and she climbs and desends with the best of them.
broncnaz
You can run the PVC off the vaccum booster line just dont expect the brakes to work as well any more. thought there was like 4 vacuum ports under a gt40 manifold? One is usually capped off. one goes to the vapor cannister one to PVC and one that goes to the vacuum t and has 2 smaller ports one to the FP regulator and the other to the EGR. what else do you have running?
Most engines need to be retuned to delete the PCV system EFI may be able to adjust fine for that but still you run the risk of building up more prressure in te crankcase and blowing out seals not to mention you wont get as much of the mositure and acids out of the crankcase with just a vent.
ilovemaui
ilovemaui
Pacific Moist West
I don't have room between the valve and the bottom of the intake to ue two of the ports. I'll try sharing the brake vacuum and see how that works. I have a hydroboot unit, just haven't installed yet.
beernut
Hampton
Those Webers look sezzy.
bmc69
x10. They just do. Here's a pic of the Weber 48s on my 351C..
Hijack over. Back to regularly scheduled tread.
Having run many old school early 60s vintage engines that were pre-PCV...I would never go back. The PCV prevents so many hassles..everything fom the oil mist that gathers all over your engine anywhere near your crankcase breather..to keeping all the other possible leaks (harmonic balancer seal..intake ends..rear main..etc) down to a dull roar.
shamu
Sachse,Tx
Hi jack I think you and Weevil need to start a Weber thread.
Nice set up.;)
bmc69
Nice set up.;)
It would be a short thread...carbs and the manifold alone add up to about 3 grand. :eek:
That 351C setup with the NOS included ran about $7500...15 years ago.
That could be the reason there are not many of them floating around..;D
Amac70
ME
There is like like 6 ports on the bottem of my gt 40 upper intake. the two on the side just above the valve covers and then long tubes under the center of the intake that had holes on both ends. Okay my gt 40 tubular is a little different then these(i believe there is 6 known differences) but same idea. where they have that other bar next to the big tube in the middle i have another tube that i had to block off also, maybe cause mine was a motorsports intake not a lightning.
Ourobos
Big Island Hawaii
If you block off the EGR port in the lower intake, cap off the valve cover hole and corresponding throttle body nipple, then run a breather on both valve covers, you will be fine. I do this on alot of forced inductions engines I build. You either want PCV or breathers, but not both or neither.
ilovemaui
ilovemaui
Pacific Moist West
The one you have marked for brake booster 2 is not available for me becaue of the tall covers necessary for the roller rockers. Even with a 1" spacer there is no room. I tried vacuum a tree but I couldn't get it tight before it ran into the tubes. That one you show is longer than the one I have. Anyway, I teed it into the brake vacuum line and it appears to be working.
