Gas Pig
- Oct 19, 2005
- 2,778
I'm eliminating the stock 3 speed sifter and putting a smooth collar back on the column. Can I also remove the shift tube without effecting the steering shaft operation. It appears that the steering wheel nut does not preload against the shift tube and/or collar but the lower steering shaft bearing. So, there would be no effect if the shift tube is in or out the steering column. Is this true?
Thanks Jeff
Thanks Jeff
