Emergency Brake Cable Bracket - Front Center Cable
HardyBronco67
Re-installing e-brake cables in '67 bronco. Old e-brake cable bracket is gone. Ordered new one. It mounts to the back side of driver's side floor plan. Don't have access to a welder. Would it work to just drill a second hole in the bracket (5/16"?) and bolt the bracket to the floor plan with a good size fender washer on the interior side of the floor plan? See bracket location on floorpan lower right corner of photo.
Jdgephar
I would imagine that would work. The only downside might be it wanting to rotate around the bolt if it's not tight. I would also imagine that someone or a welding shop would tack that on for you for the cost of a 6 or 12 pack of their favorite beverage.
H
HardyBronco67
Thanks for the advice. I've got a buddy in town that might do just that!!
WILDHORSES
USA
The design of the original bracket is such garbage. We have always added welded gussets to these when to give the bracket more support. Bolting could be a good idea. Thinking you would make a custom washer for the inside to disperse the load.
Jim
H
HardyBronco67
Jim
Thanks, Jim! Yes, I was thinking I'd likely fabricate something like a rectangular washer/backing plate - similar to what the e-brake pedal assembly bolts to at the firewall.
H
HardyBronco67
Here's the results of the bolt-up instead of weld-up for the e-brake bracket. Had a spare e-brake backing plate and cut a piece to fit at the front of the driver's side floor pan (next to where the gas tank valve is for those of you with twin tanks. It tucked nicely out of the way in the corner. I used a grade 8 bolt and washer - cut the washer to fit in the channel of the backing plate. On the underside, I used a washer and grade 8 nylon lock nut to secure the bracket in place. So far, it works great - we'll see once I'm back on the road. This was the final stage of a 4 wheel disc brake and vacuum boost conversion.
Inner Floor Pan Bolt for e-brake bracket
Under side with e-brake bracket and assembly
E-brake pedal assembly backing plate used to create backing for e-brake cable bracket
Steve83
It's hideous, but so was the patch job on the floor. The owner didn't want to dig back into it, and neither did I. Eventually, I convinced him to get rid of that thing. He never should have bought it, but he didn't actually lay out any cash for the truck. I think he got ~$12K.
Rdtrip
Fenton Michigan
That's the roadster at Jeff's Bronco Graveyard isn't it? I took nearly identical pics..lol
