Nowik35
- Aug 27, 2018
- 201
So I have two questions.
1. I think I installed my e brake cables backwards. Only one end flares out and one end comes with a clip. Does it matter which end goes on the drum which to the bracket? I currently put the clip end in the drum and at the pedal
2. Once I hooked up everything it seems I have to much cable. ( I have the stock size 3 pack from Bronco graveyard) in the neutral pedal position it seems my lever can almost touch the equalizer bracket with the two rear cables. There's not even enough thread on my retainer bolt to tighten? Did I do something wrong or can I trim the cable?
