emergency brake cable diagram
Jeepeater
anyone have a diagram of the emergency brake cables and how it connects underneath? or where can I find one? I need to finish connecting them to get it inspected. its only been 5 years now..lol
J
Jeepeater
anyone know where I can get those retaining clips? I don't think mine e-brake kit came with any.
tasker
all knowing of nothing
NH
i may have some, any parts store should be able to get them. If not let me know, i'm sure i can scare a couple up.
J
Jeepeater
Is that a standard clip or is it a special order one made just for that application? does it lock the cable in place under the body?
tasker
NH
Standard, bring the cable with you, i think it would be easier...
J
Jeepeater
Don, I have the cable from the pedal to the spring already hooked up. I also have the rear cables hooked up into my rear drums already. Im just trying how to connect the 2 rear lines to the stabalizer. I have a support on the underside of the floor with 2 holes. Im guessing the rear lines feed through there. The diagram helps. Im probably not going to get too it this weekend, unless its real nice out. Takes some pictures if your under there. Definately will help. Thanks again.
bigmuddy
Marthasville Missouri
e-brake cable diagram
Not trying to hijack the thread but what is the proper way to set the e-brake tension? I recently replaced mine and can't seem to get proper tensioning.
Ben
