emergency brake cable removal.
71massbronco
I am getting ready to lift the body off the frame. How do you disconnect t he e brake cable from the the wheel drum assembly? Seems like this may be a complicated process. is it?
Viperwolf1
electron whisperer
It's easier to disconnect the other end. Take the drums off. Unhook the cable at the park lever. Squeeze the fingers together holding the cable in the backing plate (small hose clamp works good for this). Pull cable out.
