Engine bracket question
berg bronco
franklin NC
I have a mostly stock 75 bronco with a 302 c4 and was wondering if somebody could tell me what the bracket is above the alternator... Is it stock? Maybe smog or a/c? ImageUploadedByTapatalk1391372235.269152.jpg ImageUploadedByTapatalk1391372244.965666.jpg
berg bronco
berg bronco
franklin NC
Thanks! That's what I was thinking... I wonder if it would make any sense to try and a find another pump?
broncnaz
Only if your required to have it for emissions otherwise i wouldnt bother.
broncnaz
Here's a pic earlier year but the air pumps are basically all the same even up thru the 80's
jckkys
The alternator bracket used on small blocks that weren't required to have air injection is cheap at about $25 from JBP. Any future bureaucratic emissions inspector won't see something's missing and your access to the alternator and heater hose connection will be a lot easier. Anything that sanitizes the engine compartment is a good thing.
