I am trying to wrap up the build on the 5.0 and I'm stuck at one spot and I just can't make heads or tails of what I am supposed to do.
The engine is a roller rocker 5.0 from a 98 explorer. It has NON-adjustable rockers (stock), I'm using the stock lifters, and stock push rods. The machine shop told me to check the length of the rods by tightening down the rockers all the way, put the cylinder (start with 1) on the conpression strock and verify that the lifter has room to travel and the rocker is not loose. Sounds simple but I don't get it.
How do I know when the piston is at compression?
