Engine Builder in SoCal
bronco italiano
That 240 is still quite an upgrade over stock.
Assuming that they use net horsepower methods in their ratings, that’s about a 90 hp increase over stock.
If they’re using gross horsepower numbers however, that’s still about 50 hp over stock. Maybe more.
But $14,000 for a basic rebuild? Holy cow, things are worse than I thought.
I’ll have to check with my local shop up here that has done several engines for me over the last 40 years. See if the son or a grandson is feeling the need to raise the prices like that too.
And I thought the last one was expensive at $4000!
DD,
- It is amazing how much parts have went up since COVID.
-Machine work, competent machine work at least, is at a premium because the last two generations wanted to be on a CPU and our machinists are few and far between.
-I know Panella, in Stockton is VERY expensive. However, that motor is top quality parts/machine work/builder/etc, such as Johnson roller lifters that are 1,000$ for a set now!!!!
-JBA is in SoCal, which already gets hit with a premium fee on rent, good machines are hundreds of thousands of dollars, and then you need the machinist to make a machine with a 10 thousandths tolerance be 100 thousandths. That costs a bit of money. We got too used to "Chinese prices" as coporate took everything offshore and we are paying for it- Example is Holley/Comp cams/Edelbrock/MSD and may other part makers.
-I am lucky that B & R is still so reasonable, but his equipment has been around for the 50 years he has been open.
-I am against these "Crate motors" after seeing a Jasper motor having 3 different piston sizes on one of their rebuilt engines years back, along with the warranty verbiage.
73azbronco
my 347 has over 11.5CR, but cam makes it act like a 9.5
Fordstroker has a 408 for $12,000, have not seen a 428 ish in a while, if they do, I may drop dime
My all in with pretty exotic stuff, for a 347 back in 2009, $7,500
ntsqd
heratic car camper
Upper SoKA
Numerically a static CR of ~11.5 doesn't seem all that far from a static CR of 13. It is a huge difference! 11.5 static with your kind of cam timing is manageable. 13 won't be, not on pump gas.
Look at it this way, the difference is only 1.5, but if you add that 1.5 to the 13 CR then you're at the very bottom end of a turbo-diesel's CR range.
Soylent
California
That is not a bad price compared to what some of these non-oem crate motors are going for.
bronco italiano
I paid 1000 just for ICON pistons/rings for my FE
Each quality part just raises the price tremendously these days.
I think all my machine work/assembly was maybe 2000, the rest was parts
J
jeremywatco
San Diego, CA
Ok for using the standard distributor gear. Not ok for just starting and driving it however.
And as you will likely hear, modern flat-tappet cams and modern oils are not what they once were. Hence doubling down on the advice to use a specialized break-in oil, and/or a specialized break-in additive.
And for me, I keep using the specified oils for older flat-tappet engines. Many will say that once the cam is broken in, you can use any kind of oil you want after that. That might be true, or it might not. All I know is that I hear of more and more high-mileage engines that are wiping out their cams than I remember from years passed. So I'm sticking with high-zinc oils for general use. Even after the break-in procedure is done.
And speaking of which...
My personal version of the procedure will follow. I've kept to my old version as instructed by cam manufacturers back in the sixties, versus the modified versions that have come along in the meantime. Because I'm patient and have nothing better to do when I'm breaking in the cam, than to just break in the cam! I don't need to rush it.
So mine is the following:
1. Get everything and everyone ready for first startup. Verify as much as you can, so that the engine will fire right up instantly. Or as instantly as you can make it. Cranking the engine on a starter for longer, equals very bad. A quick start is very good.
The startup is why engine builders apply specialized lubricants to the camshaft during the build.
Prep should include putting fuel into the carburetor float bowls, if running carbureted. Or pumped up if using EFI.
If you're installing the intake manifold, verify the builder used "cam grease" or moly-lube or whatever they're calling the paste, or very sticky oil substance that is applied to the lobes prior to assembly. Then pour your chosen engine oil down the valley and through the return holes to get some more in the area of the camshaft.
1a. Prime the oil pump with a priming too. NOT by cranking the engine if you can avoid it.
1b. The previous steps may already have been done. But I mention them just in case, because you need to be ready to run.
1c. It pays to have helpers with eyes. If not, you'll be very busy for awhile! Pre-connect your timing light so you can verify what's going on.
1d. Needless to say, you absolutely must have all your gauges connected.
2. Fire the engine up! And immediately rev it to between 2500 and 3000 rpm and hold it there. This may very well be the hardest part to do, for any first-timer. But do it anyway!
2a. Remember, NEVER let it idle down. No matter what you need to do, do not idle the engine. Best to stop the engine first, fix the issue, then fire it back up and run it up to the specified rpm.
3. Keep it at that range, but after the first minute or three, you can vary the rpm slightly up and down, but don't go below 2,000 for more than a few seconds, and stay above 2500 for as long as you can.
4. This period of adjustment, so to speak, should last for a full 30 minutes total. So make sure that the gas is in the tank and getting to the engine.
It does not have to be all at once, but that is better. If the engine gets too hot, you can turn it off to let it cool down. But don't idle it.
If you see a gas leak, shut it down to fix it. But don't let it idle.
If you see no oil pressure, shut it down (that should be obvious!). But don't let it idle.
Fix any issues, then fire it back up and bring it back to 2500-3000 immediately.
Seeing a pattern here?
This whole procedure revolves around not letting the engine below 2,000 rpm until at least 20 minutes of run-time have elapsed. I prefer 30 minutes, as I mentioned. But modern instructions often say 15 to 20 minutes and I've seen as low as 1500 rpm. And modern cams are often ruined in today's world. Is it due to the shorter duration, or lower rpm of the break-in? Or is it due to crappy materials? Or is it due to poor assembly? We may never know.
But I'm sticking with with 2500 and up, and 30 full minutes in my builds. So far so good, but I have not done one recently either. So I'm doing it my way, but also crossing my fingers!
Of course, I crossed my fingers every time (because I knew the consequences) since the sixties! But back then, I think crossing fingers yielded better results as well. :cool: :D
Good luck. Hopefully others here will chime in with recommendations, modifications, or whatever advice they can put forth.
Thanks Paul!
The ATK instructions mirror what you say. They say 3k RPM for 30min. Shutdown and allow to cool completely and then do 2 more times. Plus a lot of driving requirements as well.
Question, I've seen a number of posts saying to pull the bronco timing cover and install it.. i measured everything today and the timing cover that come with my motor seems the same as my original as far as depth... any reason to pull and reinstall my old beat-up timing cover?
Plan on using perma dry gaskets where i can.. i assume i dont need sealant for them. I pulled the new oil pan off the crate today and they use gasket sealer on everyhing.. lucky for me a putty knife was able to get it all off. Going to work on cleaning up my bronco pan and then painting it. It seems fine.. drain plug was stripped somewhere along the way and has a dump expansion plug in it.. so figure id tap a new one while i had the pan off.. hate to buy a new pan if this one will clean up good.
Interesting. But rewarding to hear that they're taking the whole cam break-in thing VERY seriously!
Doing it three times "should be" overkill, but perhaps it's not these days.
Regarding the stopping to let it cool down, you can actually do that just about any time. The last time I broke in a cam I did it for ten minutes at a stretch, then let it cool down in-between and did that three times. For a total of 30 minutes, rather than their 90 minutes.
But hey, if you have the time, I'm not a hater. I say if you can, then do it!
Install the old timing cover? Not sure why, unless it's different enough to cause trouble.
Depth being the same is good. But it's probably just the first in a long line of things to compare.
I'd bet that most of the different timing covers were the same depth until we got into the later '90's. Don't know it for a fact, but have a feeling...
So check some of these things off of your list before deciding:
1. Water pump fits?
2. Water pump ports angled in the same direction?
3. Meant for a driver's side (Bronco) or passenger side (most other Fords) radiator hose inlet?
4. Related to the above, where does the timing pointer bolt on?
5. Look for a dipstick hole. Plug it if needed.
6. Insert anything else that others can thing of here! ;)
I think that's correct. But wait for others who've used them to confirm if it's still a good idea or not.
What kind of gasket did they use?
Speaking of the pan... Before you go any further, check that it actually fits the block's pan rail. You know, just in case...
And check for a dipstick hole in the driver's side of the pan rail. You know... Just in case!
J
jeremywatco
San Diego, CA
Paul,
This was a fully dressed motor....
It came with water pump already installed. I took my bronco pump and its the same in every aspect.
It came with harmonic balancer installed and timing pointer installed. ITs on the drivers side.
All dipstick holes currently have plugs in them so we are good there.
Trying to keep as much of the stuff it came with as possible.
Pan gasket was cork gasket smothered in gray sealant.
Should be fun!
69Lawdog
That was the polite way of saying "get lost". They'd rather spend their time building a high end engine.
I've had several stock GM motor short blocks and heads done in the past at Orange Engine In Anaheim. They've been around for 40 years but don't advertise. It's more word of mouth in the Orange County area.
I can't speak for their work over the past 12 years since I don't live in the area anymore, but they're still in business.
1911 E Ball Rd, Anaheim, CA, 92805, United States
714-635-4030
Orange Engine In Anaheim has closed and has tons of negative yelp reviews before they left lol
Would love to find a So Calif engine builder if anyone has come across one yet. I had a chevy 350/383 rebuilt but like the other gentleman said mine was like 14K removed, rebuilt and replaced. not trying to do that again. Id like to rebuild 302 but leaning towards blue print fully dressed
joebronco73
Lago Vista, TX
Thanks! Mine has a C4 and Dana 20. Both are out for rebuilds as well right now.
I ended up buying that ATK engine should be here in a week or two. I think I will eat the core deposit and keep my core. Who knows.. maybe some day I will find a reasonable local builder and rebuilt it for this or another project.
Once it arrives I'll figure out what is needed to mount it up. For sure the oil pan.. may need to move over my existing pertronix dizzy as well.. the photos look like the HEI dizzy it comes with is pretty tall and will hit my hood. Pretty sure I can mount my C4 right to the 50oz flexplate it comes with.
I know this is a bit old, but I'm from the San Diego area as well. My uncle works at a shop in the Wintergardens/Lakeside area (he did the balance on my engine in ~2006). Anyhow, the shop was Ed Hale Machine, and, if you're familiar with the old Cajon Speedway racers, Ed Hale was one of their drivers from the 70's and known for wearing a tuxedo under his racing jumpsuit :ROFLMAO:.
Anyhow, the shop is still there, as GRC Performance (their shop foreman Gary Camp took it over, after Ed's passing). Should you rebuild your stock engine, I'll see if my uncle can help out.
