Hey gang - a question for the engine builders here:
I'm working on building up a 363W with a custom FTI cam. I'm on round 2 on the camshaft due to issues with the first grind, and the second cam that was delivered has a much smaller base circle. When installed at TDC the lifters drop below the top of the dogbone leaving ~.040" overlap between them. Will this work?
Only realized this issue as I was planning to assemble for good. If it's not going to work I'd rather figure that out now than when I try to start the engine!
The engine is a Ford Boss 363W short block, Ford R302H lifters, stock dogbones and retainer. I'm generally pretty frustrated with FTI and the delays I've experienced and the total lack of customer support. More on this later in my build thread (which hasn't been updated for over a year!), but this is the engine for my Bronco. Just trying to keep it creeping along and get some parts out of boxes and where they belong!
Thanks!
Thanks!
