Engine Codes for 200 and 250
DrDanWWW
The Ford Falcon Six Handbook shows the same engine codes for 200 and 250. A 1975 200ci is marked D5DE-AA. A 1975 250ci is marked D5DE-AA - both according to the Handbook. Shouldn't the 250s be D5BE? Is this a typo?
I ask because someone is selling a 250ci but a photo shows "D5DE." Is it really a 200?
Bajabrewer
Count the water pump bolts - 4 bolts is a 250 3 bolts is a 200(or 170/144)
I've got a 250 and the head is marked D5DE(same for 200 or 250) and the block is D6DE
I was told it came from a 76 Maverick
bmbm
head casting codes for 200/250
I beleive those are casting numbers for the head which was the same on the 200/250. Look for the block casting numbers because the 200 blocks are different than the 250. Don't have my Handbook handy right now.
DrDanWWW
DrDanWWW
I will see if I can see the waterpump bolts from the FB Marketplace listing. 2. The listing didn't have an upclose photo of the intake manifold. Actually, I am really interested in the head anyway. I'd love to find a late model 200 for my Bronco. I know some owners say the 250 clears the hood, but I don't trust my '66's hood clearance. (don't want to modify either) I'd be up for mating a late 250 head to a late 200 block. BUT I am not an engine guy nor a hotrodder. Thanks for help. Let me know what else you come across.
stout22
Athens, AL
I agree, I'm not sure how anyone was able to have a 250 clear the hood without a body lift.
I have a 250 in a 71 but it has a 1.5" BL that barely clears the breather.
B RON CO
Statesville, NC
Hi, all 250s have the 4 water pump bolts and the Small Block Ford bell housing, which has the low mount starter. The early 200s and most later 200s have the high mount starter. The Broncos have the high mount starter bell housing. Maybe you can see the starter in the add. Good luck
Bajabrewer
Forgot that one - Bell housing is a good telltale - it's a rare 200 if it has the low starter.
bmbm
Well if you want the head the D5 was a 1975 casting which is a large log head and that is good.
66 1/2 cab
How does one find a 250 straight six,I have a170in my bronco then got a 200. I do like the straight six’s because I had one in Ford falcon station wagon in collage. I just want to get more power then my 170. I’ve looked for a 250 but can’t find anywhere.
DrDanWWW
DrDanWWW
Thanks folks.
Of course Ideally those of us who want to stay with the inline six, would like a late model 200. And it is a good option to mate the 200 short block to a 250 head. That doesn't create a hood clearance issue. I keep looking at old junk yards for a 77-80 Fairmont, Granada, Zephyr, etc - trying to locate a 200. That said, there seems to be a slow steady flow of '66+/- 200s out there - mostly someone pulling one from a mustang. But if I am going to go to the trouble and money to have a 200 rebuilt then I want a later model. I guess the machine shop will charge the same whether it's a 66 small log/small intake/smaller valves, or a 79 200 with larger everything.
DrDanWWW
DrDanWWW
Sorry, forgot to respond:
The FB Marketplace photos show the block numbers only...
bmbm
block casting code id
That is probably a 250 block 1975 casting code.
