Engine Guru needed, help with heads/rebuild kit
rojo23
Ashland, VA
I am getting ready to tear my engine apart and start the rebuild. The local tech center offers a rebuild class, and you do all of your own machine work and then put the engine together yourself. My question is that I would like to add some ponies under the hood. I have been doing a little research, and look like the GT40 and GT40P heads are a fairly inexpensive upgrade. I know that you lower the compression with these heads, but I was looking at summits rebuild kits with flat top pistons.
http://www.summitracing.com/parts/fem-mhp174-300/overview/make/ford
this kits said you can expect about 9.08:1 with 58.2 cc heads. This is what the GT40 heads are.
The other kit
http://www.summitracing.com/parts/fem-mhp173-400/overview/make/ford
says you can expect about 10.13:1 with the same heads.
Question what is the better option? What type of cam and intake should I run? Will this be ok on pump gas? Any input would be great. Thanks
Mountain Ram
Recovering Masshole
Abingdon, VA
9.0 would be bettr with pump gas- that is about what the stock explorer 5.0 runs. That same explorer runs flat top pistons with valve reliefs... And you will likely need the valve reliefs with the GT40 heads (likely from an explorer).
I thoughtbthe GT40 heads were like 64cc... I may be wrong- I havevlooked at a lot of heads recently...
R
rojo23
Ashland, VA
looks like the GT40P are between 64-65cc, so does that mean that the flat top would expect less than 10:1? I don't know a lot about engine stuff.
Annapolis76EB
Annapolis, MD
I just went through this and have the GT40s in my Bronco. I will say that the 5.0 roller is a much smoother and efficient engine. I am getting 15 - 16 MPG now and was barely getting 9 with my 76 306. One note of caution; do not expect to have your doors blown off by a plain 5.0 with GT40 heads. I can tell a slight upgrade in power at middle and higher RPMs with the GT40s, but my low end torque is nothing to write home about. Most likely this is due to the fact that I am running a Cobra cam, but even with another cam I dont think a 5.0 is going to blow a 306 away. If you have a stock 302, you will probably see more of a difference than I did. If you plan on driving your Bronco regularly, I would stay far away from that 10:1 setup unless you want to get in to 93 octane.
For me the greatest benefit of the 5.0 is effeciency and a really smooth running reliable engine. I already had headers, 1406 carb, performer intake, etc, so the swap to GT-40s really didnt blow me away like I thought it might. That said, I am really happy with he swap (now that its running awesome) but I wouldn't dump tons of money into GT40s expecting a completely different driving experience. Hope this helps and feel free to PM me if you have any questions.
Mountain Ram
Recovering Masshole
Abingdon, VA
Both are flat tops... The second does not have valve reliefs, but you will need the reliefs.
The stock mustang cams... And Cobra, do not fully use the GT40 heads- from what I have read. The explorer cam even seems to have more grunt for the heavy Bronco. If you will be throwing a new cam in, call one of the major cam companies for some suggestions.
A 306 isn't radically different enough for the 302 in cubic inches to change much of anything. Engines are just big air pumps. The more air you can move- the more power you can make. Heads and cams make the biggest difference... But should be matched to the intake and exhaust...
I am no expert... Not even close! I am building a 347 stroker and have been reading everything I can get my hands on for months! Don't be afraid of it though. Take your time, do your homework and enjoy the process!
Todd
broncnaz
The Gt40 heads spec anywhere from 60-64cc where the gt40 P heads spec out 58-61cc. Of course I've seen numbers all over the board for both heads some lower some higher. Get your heads and figure out what CC you have and if you want to mill them or leave them as is then pick your pistons. I would shoot for around 9.5-1 compression. Of course camshaft choice can also affect compression ratio choice. But for the most part somewhere bewteen 9.1-10-1 should be fine.
As was said your not really going to see a huge differance by swapping heads unless your looking at dyno numbers. The gains really only show up at high RPM's
You might want to check your stock heads out closely. See what they have for combustion chambers. You may be better off modifying them. Since your machine work will baically be free. You could install larger valves something like 1.90/1.60's clean up the exhuast ports and do some gasket matching and you'll have heads that are as good or better than the gt40's. For about the same money as it would cost to buy gt40 heads and rebuild them.
Camshaft choice is the most critical part of building a engine as it makes or breaks the engine. Cam should be chosen based upon axle gearing, tire size, and driving needs. to big a cam and you lose lowend power might even hurt midrange. To small a cam and you have great lowend but no topend you may run out of steam before you get going. Most people use cams like the edelbrock performer or something with similar specs.
blubuckaroo
Grease Monkey
Ridgefield WA
If you plan any work on a SBF motor, you need a copy of this book.http://www.summitracing.com/parts/hpb-hp89?gclid=COKptrPSqrQCFUlxQgodVmEA3w
I built the 302 in our Bronco last year. I used a machine shop/engine supply shop to do the machining, piston fitting, rod re-sizing, and cam bearing install. I did the rest of the assembly. It's good work and very rewarding. I recommend it for anyone with the space and tools.
R
rojo23
Ashland, VA
thanks everyone for the input. I will mostly be on the street, probably not much off roading. I plan on having 35" tire, and eventually change the gears to 4.11. I have a t19 4 speed trans going in. Seems like the cam is the most critical part of the build. I will do some research before buying.
Kegger
belton,Texas
sbftech jim ,owner of fordstrokers has engine information vidio for about $10.00 a month theres over 150 vidios to learn from. covers engine build and design. from one of the best ford men around. as far as gt 40 heads, the E-7 heads re cnc mech sprung w/ 190/160 valves done $845. a pair. swaped new viton seals the works. much like the windsor jr. but has better flow I gotta look up the guy hes out of cailf. cam choice is the heart beat. the stock cobra cam but 1.7 rollers and push rod change on the exhaust valves will give you a 264/ 270 duration, plus or minus don,t quote me cam without buying one. or 258 always check p to v . clearance. gt 40 top, 306 roller shortblock 300/325 hp. done 2K price tag . strokers 3k plus,supporting options 351w stock 357 .30 over 1k if you do your home work.
