Ok, can anyone who cares to, chime in on which is a better engine for the Bronco? I have both and want to see what you guys think:
Engine #1
Brand new HP 5.0 with windsor firing order (Surefire engines) with advertised 300HP and 336 TQ. 9.0-1 comp., Hypers, cast oe iron heads, at 1.77 intake 1.46 exhaust - lumpy cam at like .498 .498 lift 219/219 duration. Edelbrock manifold
Engine #2
Used '94 roller 351 from F-350 with 67,000 miles or so on it. (I saw it run in the F-350 prior to being taken out and seemed fine). Had a machine shop go through it - guy said he was amazed at the cross hatch still left, re-ringed it, added trick flows with new 2.02 intake valves and I believe like a .194 exhaust vales, all new, , heads were shaved slightly so I'm guessing around 60cc's? Comp Cams 1.6's put on the heads, new rods, stayed with stock cam, new timing chain, Edelbrock manifold.
stock pistons with a relief so big you could have a square dance. So, I'm thinking stock comp. around 8.3-1 ?? Not sure with the trick flows what that would have changed it to.
Daily driver/kinda' sorta' show rig type driving most likely. Love to hear what everyone has to say, come to think of it, lets put a poll in here
But, more interested in your thoughts, see where this goes... Thanks folks.
Engine #1
Engine #2
