Thanks for the pictures. Helps a lot I think.
Maybe the PO was having the same issue, because that's some overkill on the springs. But I see one thing right off the bat. Your primaries are way open in those pictures.
The scondaries are closed it appears, but if you look beneath the choke plate over the primaries, the light just lets you see the angle and they appear to be almost half-way open at this point.
BIG PROBLEM as you can imagine.
It's an older Holley, possibly a 600cfm with a manual choke. Possibly originally an automatic choke, converted? Not sure, but it's not the same mechanism as the manual choke on the old #1850 model.
I didn't bother looking at any of the numbers on the air horn yet, but I'm sure someone here can decipher them and tell you exactly what you have.
The choke linkage is likely stuck, but you have other issues as well. As was pointed out, the forward return spring is wrapped around your fuel line and may cause wear in at least one, if not two places.
And at the rear near the firewall, the mechanical throttle linkage is rubbing up against a wire bundle.
Neither of those is a good thing, for all the obvious reasons.
As someone also said, you might try spraying carb cleaner all over the carburetor and associated linkage, then some lubricant (even just some WD40 would help) over all the pivot points and linkage junctions and anything that moves.
Once all physical interference points are taken care of as well of course.
What about a choke knob on your dash? Are you familiar with using a manual choke on an old carbureted engine? Familiar with carburetors at all, or just had EFI engines in your past? Some few, but important differences in how things work.
Your choke plate is open, so that's good, but if it's not opening all the way or if the high-idle linkage is catching and not releasing it will hold your throttle plates open. And if it's not adjusted right, it'll hold them open too far.
In neutral, it does not take much of an opening to rev the engine to the moon. But your throttle blades look to be open a LOT.
You can double check that at your end. Maybe it's just a trick of the light in the images. But if you look down the front two barrels/venturi under the choke flapper plate and they look angled farther open than the two at the rear of the carb, then you need to fiddle with the linkage to find out why they're stuck.
