Engine redlines without gas peddle
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Sounds good, I’ll give it a sprite now let it sit for a few minutes and then turn the ignition. I’m bringing it to a mechanic tomorrow anyway I’d like to drive it there set of having to pay for a tow truck.
Yeah, that would be much more fun both in the driving area and the pocket book.
Does not hurt any of the stuff to spray those cleaners and lubricants down the throats of the carb, or around it's outside linkage areas. Including the passenger side linkages.
The only thing that the cleaner will typically hurt is newer paint. Since the intake manifold is bare aluminum and the carb is whatever it is, spray away.
Frankly, with old fully cured paint, you have to use a lot of cleaner repeatedly to hurt the paint, unless it's already compromised.
But with new-ish paint it'll mess it up. Not as bad as brake fluid, but not good for it.
But like said, around the carb area you're fine.
The other good use to put carb cleaner spray to, is while the engine is idling spray it around seals and gasket areas to see if the idle speed or quality changes. If it does, you have just sprayed into an area with a vacuum leak. And vacuum leaks are the bane of our existence sometimes, and really mess with a smooth idle.
Good luck.
jckkys
Your carb needs help. You have a Holley List#4548 450CFM 4bbl. These were built with automatic chokes. Yours had the automatic choke mechanism defeated by the cheesy, make believe pull choke conversion. Here;https://www.ebay.com/itm/Holley-45-...507998&hash=item5908b7c3c5:g:PaAAAOSw4oNamuRL, is a real Holley mechanical choke conversion. A thorough disassembly, cleaning, and reassembly using the correct carb kit is a good place to start. I don't see place where the throttle linkage sticking so the secondary is the next suspect. The only thing acting to completely close the secondaries is the diaphragm spring in the vacuum secondary housing. You have the quick change cover that speeds up spring changes when tuning. Just remove the black plastic piece to see if the spring is OK. The secondary throttle shaft has to be absolutely free to rotate or the diaphragm spring can't close the throttle. Be aware that intake manifold vacuum increases resistance. So secondaries stick more with the engine running. Since the choke stove and plumbing appear to have been removed you have a choice. 1. Repair the choke stove plumbing or go to an electrically heated choke thermostat and the clean the automatic choke. 2. Install a real Holley mechanical choke conversion I cited above.
The throttle return spring hooked to the fuel supply hose is even more cheesy than the make believe pull choke conversion and invites interference with other parts besides pulling the throttle lever in a odd direction. It also duplicates the return spring below the throttle shaft. So it's likely not needed.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
After taking another real good luck from the top I can see that the primary is wide open. The valve does move when I move the throttle but it doesn’t completely shut.
jckkys
The fast idle cam on the defeated automatic choke mechanism is likely holding the throttle partially open. A casual glance tells me the throttle isn't wide open. The throttle lever would be pulled fully to the rear. That original automatic choke was wrecked in terms of function. Get the mechanical choke conversion made by and for Holleys. It's time to learn something about carburetors by rebuilding your's. The kits explain most of what you need to know. There are also several books on installing, rebuilding and tuning Holley carbs.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Thank you very much for all of your help today! Really help me understand how this whole thing was put together.
On that note, I did buy this truck knowing it’s going to need some work and I was prepared to make some improvements to it. Do you think the carburetor that is on now is worth repairing or would you guys recommend another one that is not only better but will last longer to?
B RON CO
Statesville, NC
Hi, your carb is pretty old. The new ones don't have bowl vents on the top anymore.
I would play around with it for the learning experience.
I would probably replace it with a new Edelbrock 500 cfm or Holley truck avenger, with vacuum secondaries.
Tinker with the old one and learn up on the new ones.
If you pick a new carb you also have to decide on manual choke or electric choke.
You got some good insight on the carb.
Make sure to check the choke cable is working, gently pulling out closes the choke, and pushing in fully opens the choke, and works the high idle cam. Part of the problem is the manual choke carbs have a smooth ramp for the high idle, and automatic chokes have a stepped ramp. So the choke cable will not work properly unless you have the gas pedal pressed down a little.
So you may have to adjust the cable clamp on the side of the carb, to make sure the choke is fully open, and the high idle is off, when the choke is fully pushed in.
I think that crazy spring going to the fuel filter is for the tranny kick down, which should be that way, to pull the kick down lever forward.
Good luck
jckkys
The carb needs a rebuild that includes a thorough cleaning. That's all it needs. The 4548 is the perfect size for 302s. Ford sold them as replacements on 302s, 351s, 352s, 390s. and 428s. So they're plenty big enough, but also not too big. They're designed for Ford linkages including the C4 kick down. Your engine compartment looks '76-'77. Is it? A brief description of your Bronco including the year would help us help you.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
It was this truck; I bought it from a member: https://classicbroncos.com/forums/showthread.php?t=294708.
All body parts are new except for doors and hood
New floors
1978 FORD special edition wheels ("free-Wheel-n" option)
fresh 302, SS headers, mild cam and Ford racing intake
new shocks and brakes (all stock)
rebuilt trans w/mild shift kit
New tires (less then 500 miles)
new carpet / and OEM seat covers front and rear
Ford Med. Lime metallic (1969-70 BOSS 305 mustang option)
original trailer hitch (aftermarket from 77ish era)
LED taillights
Allot of other "misc" parts that are new
pipeline010
go ahead and clean/rebuild the carburetor.
it's one of the first things I had to do on my truck and, just 5 months prior, I hadn't known what a carburetor was. seriously.
find a youtube vid on carb clean/rebuild, best if you can find one to go with your carb, but not necessary. take your time and don't rush, take lots of pics. anything looks off or you need help just ask here...you've seen how quick people are here to help.
my truck still has a lot of mysteries to me but fuel isn't one of them. I now can have my carb from intact on truck to completely disassembled on my kitchen table in less than 30 minutes. I remember a mechanic telling me I might need to re-jet my carb when I first bought the truck and me thinking how scary that sounded. now it's a "hold my beer" kind of job.
rebuild the carb. they sell kits at your local big box.
...I remember a mechanic telling me I might need to re-jet my carb when I first bought the truck and me thinking how scary that sounded. now it's a "hold my beer" kind of job.
That's a fantastic description pipeline! Love it.
And a great testament to how fun it can be to still learn something, including how to fix and maintain old machinery like ours.
And sounds like it's become fun (to a point only, I would imagine?) as well. With any luck, fun for the whole family.
Thanks for the words of encouragement.
Jfryjfry
Hey Bostonbronco! I’m in Quincy for work and have tomorrow off. Let me know if you’d want to get together to look at that thing. Email me at my username at yahoo
pipeline010
...great testament to how fun it can be to still learn something, including how to fix and maintain old machinery like ours.
only not fun part is the truck being my primary daily driver. when it goes down it's a big deal. when I move and have a proper storage place I'll be getting a mile beater....then repairs can be more relaxing and fun rather then a must-do stresser.
Rustytruck
Things to note. Fuel hose clamp is not tight
Front facing spring on carb is for the down shift lever for the automatic transmission. You need that spring so rerouting is best. Doesnt need to be so heavy though. Bowl vent on carb fuel bowl is disconnected.
When you look down the top of the carb the small holes in the venturi are crudded over these holes need to be clean for the carb to work properly.
I would also chech the fuel level in the carb and also check that the float isnt stuck. Also check that you dont have any open vacuum leaks.
jckkys
There are 2 return spring brackets needed for your Holley one here;https://www.ebay.com/itm/Holley-20-...833128&hash=item23587faf60:g:xN4AAOSwGvhUAPju. is screwed down on the front left side foot. The other could be the one below the throttle shaft. It needs a real return spring bracket like this;https://www.ebay.com/itm/Chrome-Thr...G4AAOSw8UtbOg13:sc:USPSFirstClass!85711!US!-1. With these and a decent fuel line your engine compartment will tell folks you know what your doing. Oh, I almost forgot the real mechanical choke conversion.
rustbucket
You can peddle(sell) gas, but push the gas pedal.
Sent from my iPhone using Tapatalk Pro
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Hello again;
I finally heard from the mechanic. The irony is that when the truck got to them it wouldn't turn over. Apparently, the original owner installed a neutral switch that was not secure and eventually came loose. Once that was fixed, they started work on the carburetor and found that the throttle plate is cracked/broke and has deemed the whole thing as "junk".
As much as I wanted to rebuild the carburetor (you guys got me amped about it), I'm going to move forward with a replacement so I can be confident that I can get to Point A and back home again. If they haven't junked it yet, I'll ask for it so I can take it apart and poke around.
I really appreciate the time and advice you've given me during this whole process. I hope I can repay the favor sometime in the near future.
jckkys
There is nothing obsolete about your carb. Holley made them until a few years ago, I think they still make List #1849s that are about the same as 4548s, except for the lack of Ford kick down and throttle linkage. What exactly cracked on yours? I'm betting it's the base plate, from over tightening. The throttle plates are 1 1/2" diameter steel discs. I've never seen one crack. Just to prove a point, I'll repair/replace your base plate free. If you want I'll PM you with my address. Just send the base plate and I'll send it back to you in no more than a couple days, and include a real manual choke conversion. It doesn't sound like your "mechanic" is able to work on carburetors or is unwilling to. Don't let him through it away.
pipeline010
that's an amazing offer right there!
ya, I'm not sure about a carb base itself "cracking." WARPING, yes..if over-tightened they can warp and then you've got yourself a vacuum leak that needs to be machined (I think?) to flatten it out again. if it's the base plate cracked that's not a huge deal.
but one of the first things I learned was that newer definitely doesn't mean better for these trucks. I love my original 2 barrel motorcraft and as long as I can I'll be leaving that on top of my engine.
