Engine temperature gauge is pegged out
norm02
Hey guys,
I've had my freshly rebuilt motor running a few times but I am chasing down the cause of it not wanting to idle. That being said, as soon as I start it up, (cold start) the temp gauge pegs out.
I'm guessing that either my sending unit is bad or there's an issue in the wiring which is a little on the sketchy side. Before I order a new sending unit I wanted to ask the experts and see if there's something I should check before I buy replacement parts.
Thanks!
Viperwolf1
electron whisperer
Unplug it at the sender and see what the gauge does.
If gauge still pegs, wiring or gague issue.
If gague says cold, bad sending unit (or some severe grounding issues between engine and body that should be causing a whole bunch of strange electrical issues)
DaveLev
If you cannot find someone to help you test, you can run a 6' jumper wire from the wire under the hood at the sender around the hood and door and fire up the rig, and when it is not touching ground it should read cold, and when you take the jumper wire and hold it to your roll cage it should move the gauge. Just an option.
5001craig
I installed a new sending unit going to the stock gauge initially with my new motor. Temps were off (low). Just installed a mechanical gauge and temps are accurate (higher than originally). My engine builder is all about mechanical gauges and recommended that for both the oil and engine temp. Here's my gauges I got from O'riley's (needed them fast):
hRAohqmBghr9kbQz6PxmuI6b-_5pyvqtR6ikk6w0hC8VTdfDMqjTw_GY-v0gFeblbTTtV_7y49txq9q63B3_wb0sCcpCIjTHiq1YkIO-bYmThwt8czegh1yMK8EMJ1vMUcnvP6VtJ-c1EjTV7XrKDMSl_wIBIRVYMzJpNc6CbYxmuD3JeMyaCq_ui5doNlJ55LWzTeJo8jiDH3n3_7ggptZbaeAifr_jF7kzSmd_NRQrzGqEzpDGNvjjugmx2rGHyh6fYKIQh0JksU9gpz80hO4MT4QTjhxoKMcEPJ_MjF5KwSewrH6-SqSl-4FpLxUwpikDSqWCqu9UOVPAnRXJliUGYc1RwTx8mrhx3nw87gP-gyCPjuhkPyNrR59_V3Lq_KrFsSV3nx3kosUrS5YLIOP5M41eHhwgV6TIcc6iPtHN2WshbmMBmgaHMnjE4QUcePIjzQnklAMG2-b4IkxwPyCg4swPOH-1KvgB-gp8w0vds_eoNKyA9duqEiyJxcxyKtKIv3mmNgptcj4fw5OAraA0PafsBnO_zlqzhhwqZ9lizFZvvQH3zvOJYluCnTevOcjqkZLZ3WkfT2CwQw6fYEynLAF9b6LQ=w1753-h985-no
norm02
norm02
Tempted to do this if I cant easily fix my current problem. As I mentioned in my OP, the wiring on my truck is sketchy in some areas and this may be one of them. Because of that, I'm planning on completely re-wiring the truck at some point.
In the short term, I want to make sure that my new rebuild isn't getting too hot especially since it's going to be 100*+ for the next 30 days. An inexpensive mechanical gauge might be a good patch until I can get the wiring sorted out. Thanks for your help everyone
Crush
Greenbottom, WV
Which sending unit do you have. If it is one for a warning light (idiot light) then the guage will peg out. If it is a later model sending unit for a guage ( looks like a little plastic hat) that is the same as an idiot light. Sometime in the 90's ford made a decision to use the same sending unit for guages and lights. Problem is they put a resistor in the guages to make the needle show up in the normal range. So if you had any oil pressure at all it would read normal. Those sending units send a signal until they read no pressure this make a real oil pressure guage peg out. The sending unit you should have looks like a big bell and is on the end of an adapter to get it out past the block to fit
If it were an idiot light sender it would read cold until it overheated at which point it would move to full pegged hot.
The oil sender is the one that works backwards if using an idiot light sender. Reads pegged with no oil pressure and reads no pressure when there is some.
DaveLev
Just going to add my 2 cents about the Equis (sp?) brand of gauges. In my opinion, they are crap. I've had them in 2 cars - both that I bought with them. I have replaced several of them in the past few months - 4 total, including the speedo, tach, and fuel gauge twice.
Yes, they are half the price of AutoMeter...I get that. And yes, I've heard some of the AutoMeter gauge lines are of lesser quality than the race-spec stuff. But having a crappy gauge - like the tach - kill your engine/ignition system really isn't worth saving a few bucks.
Opinions are like a-holes...everybody has one. There, I feel better.
So Norm, did you ever just pull the wire off of the top of the sending unit to see what happens? Takes just a few seconds to do with the stock push-on connector. Longer to open and prop the hood up in fact.
Do that, turn the key on and see what happens.
If you did already, what did you find?
norm02
norm02
Sorry for the delayed update. Replaced the sensor which screws into the back of the cylinder head and it now works. Found the sensor at my local Autozone FYI
