Ok guys, i have a problem that I have ignored in hopes of simply buying a new engine. Well that is not going to happen anytime soon so I need to try and determine what my issue is and if I can fix it cheap or if I will be better off buying a new engine.
I have a ticking noise at high RPMS\Speeds. I cannot reproduce the issue in the garage by reving the engine.
It happens when driving at about 65-70 mph and only when I'm giving it gas. Couple of examples:
1. If cruising at 70 mph and not giving it much gas, there is no noise. If I give it gas to "pass", then the tick occurs. If I give it more gas to "pass really fast", then the tick goes away again. In other words, I can throttle the gas to make the tick happen or push through it by flooring it.
2. If I try and drive faster at say 80, then the tick is constant. Again, if I floor it, it goes away.
3. This happens regardless of being in 4th or 5th gear but never happens in 1st - 3rd but I am also not reved enough or driving fast enough to occur.
4. If I leave it out of gear, and rev it up, I never hear the tick.
Not sure if this is enough info to start troubleshooting but let me know what you think or what I can look at.
I did try and put some engine cleaner in it, thinking it was maybe a sticky valve but it didn't help. I did only try one bottle on one tank of gas. Do I need to use it multiple times?
Thanks in advance for any ideas.
