I have a 66 Bronco with it's original 289. About 10 years ago I put the NV3550 5 speed in it and it has been awesome. However, a few days ago, I tried to start it and it would not turn over. The starter would engage but wouldn't turn the engine. I charged the battery, then I replaced the starter solenoid and starter. It still would not turn over, I then tried to started it by pulling it and popping the clutch with the transmission in 3rd gear. I replaced the starter cable and one of the battery cables. I checked and the starter is getting plenty of voltage. I also tried a cable direct from the battery to the starter lead at the solenoid. The engine would not turn. In fact, when I tried to pull start it, the tires were dragging on the pavement! The engine ran fine the last time I used it a few days before. It appears that the engine is froze. It has oil and showed no signs of problems previously. How do I figure out what is wrong?
