- Jul 31, 2001
- 8,996
So a buddy just bought an ibox and I'm thinking of going Titan... so with a Ford 4r70W, aTitan and 205... one or two rear crossmember (rear engine mounts)??
Atlas evenm for their 4 spd recommends a single crossmember (usually stock at the rear of the trans)
Do I need 2 cross members for running a Titan with my trans and 205 or is running just a beefy single transmission mount under the transmission tailshaft (stock mounting point) just fine? I really don't think the additional 20lbs or 205 weight determines if it needs an additional crossmember over an Atlas at 20lbs less... to me it's the extra 5.3" of ballast hanging out past the end of the rear mount and hanging on the tailshaft of a 4R70W.
I have 710ft lbs of torque and 40" tires. I don't bounce like crazy when rock crawling but I use my rig...
I've gotten some great suggestions for what I will have to do if I go with two crossmembers. If I have to go with 2 crossmembers: even weight on both, having the mounts designed as similar as possible so torque transferred thru each mount is as equal as possible...but do I need TWO?
I'm just concerned about another 5.33" extending the 205 out farther w/o an additional crossmember.
Here's my experience with them.
I ran a ZF/203/D20 for over 12 years and ate Dana 20's for lunch and used 2 cross members w/351W
I then ran a 4R70/KluneV/Atlas combo with 2 crossmembers w/o incident for about 6 yrs w/418 stroker
I've run a 4R70W/KluneV/205 combo with 2 crossmembers w/o incident for the past 2 yrs with 418 stroker
I now run a 4r70W/KluneV/205 same combo but with a 460 SBF
I plan on running a 4R70W/Titan/205 combo and thought I'd ask opinions and what HAS or HASN'T worked for wheelers... and why??
TIA
TIA
