rmfreeze
I've got a slip joint at the header collector and the exhaust pipe just won't tighten up on it. The exhaust pipe goes over the header collector fairly easily - it isn't tight. I would say it's snug - not sloppy. The kit came with a band clamp and as I tightened it I had my doubts about the allen head bolt on the clamp. Sure enough - the allen stripped out well before the pipe was tight. I just don't have luck with allen head bolts in tight situations - the allen strips out too easily. So I changed the bolt out - it was a 6x1.0mm and I just happened to have one with a standard hex head. I could get lots of leverage on it and got the clamp as tight as it's going to get but the pipe is still loose. I can pull it off by hand. So I then tried a standard exhaust clamp and it was a little tighter than the band clamp but still not tight - I could pull the pipe off. I tried using an impact on those nuts and ended up breaking the u-bolt.
I'm refraining from welding this because I want to be able to take the exhaust pipes off without cutting them off. I thought about making a thin cut in the exhaust bell to let it compress easier on the collector. Any hints?
