Big Slim
- Dec 11, 2007
- 306
I was installing mine based on efiguys diagram and what I could find online. I ran the diagnostic on the unit and showed bad brake circuit. Looking again online I found a diagram showing the brake switch going to ground when brake is not pressed. So I grounded that circuit temporarily and the diag worked with no faults. I was using a focus switch that’s is only open close. no pin when open to ground it. What brake switch can I use to make it go to ground?
this page shows some diag for it and says it should be ground as well, well less than 20ohms from pin 4 and 10. https://www.supermotors.net/registry/media/322459_1
![bada21b1da84675d7d77ab984e8047be.jpg](http://uploads.tapatalk-cdn.com/20230703/bada21b1da84675d7d77ab984e8047be.jpg)
