John Griswold
Getting close to starting the new Explorer swap. I was wondering if before I put on the upper manifold would it be possible to cycle the fuel pump and pressure test all the fuel line fittings and injector seals. EFI Gary says the pump will run for 2 seconds each time the key is turned on without starting the engine. The line could be vented through the Schrader valve. Can this be done? Should this be done? I also have the Fuel pressure gauge to go on the Schrader valve.
