Explorer swap question
STalon89
Running sanderson headers on this motor swap with GT40P heads. Am I needing to run certain plug wires?
bigmuddy
Marthasville Missouri
With the Sanderson header I don't believe you need anything special. With that said, and when using any type of header due to a better heat loss I prefer to use a quality high heat plug wire and even a heat retardant boot. I have wasted too many plug wires that have laid up on a header to count.
Good luck, you will love that explorer 5.0
STalon89
STalon89
Another one for those following. Oil Pickup tube the same as the bronco 302 on this motor? Or do I need the specific one for this year? I imagine it just differs due to pan design?
904Bronco
San Martin, CA
Are you using the factory Bronco pan? Then use the factory Bronco pick up
If Explorer pan, whether it is steel or aluminum, use the pickup that came with them.
