71BroncoSport
- Nov 2, 2013
- 78
I've been fighting a problem where it runs rough between 1k and 2k rpm's. Once over 2k, it runs strong. I figured it was running too rich. I hooked a Scan Gauge into the ODBII port, and it's NOT throwing a CEL, but in the history it had a P0102 code suggesting "Insufficient air flor through the air filter". I have a new K+N and it's still clean. So I put a new MAF housing and meter on and instantly it is running so much better. However, I can still feel a SMALL hint of it chocking out, but can definitely live with it.
A few days ago I was heading out on a big 75 mile trip and I could tell the engine was struggling, specifically up a hill. I made it up, but could tell something wasn't quite right. When I merged onto the highway, I couldn't get over 40mph and it quickly started going slower and slower. I pulled off and checked the Scan Gauge. Now it had either a P1151 or P1152. I don't exactly remember and it's not in the history anymore. This is suggesting something with the O2 sensors, but I'm guessing that's not the source of the problem.
Pretty much every sensor is new on this thing. I checked to make sure the O2 wiring wasn't burned and everything was fine.
I start to limp home and I can't go over 2,500 rpm in 1st. Running like garbage. Then, like someone flipped a switch, it runs strong. I shift into 2nd and it's strong. I'm thinking I can merge on, but eventually it runs bad again. It did that 2 more times before I was able to limp home.
Any thoughts? I'm going to try and program this scan gauge to look at the fuel pressure. I also ordered a Idle Air Control valve as a shot in the dark, but I think the one on there is new within the year.
Is it possible to foul up O2 sensors in a five hundred miles??
Any input would be appreciated!!
