I cut the castlated portion off the bolt only. I didn't want to lose strength in the bolt or go with a thinner washer. If the bottom isn't fitting then you definitely have the wrong timing set. I have an extra set, Cloyes C-3057K, and it measures 0.975" thick with chain on crank gear.
