I've got the 5.8 EFI installed and running (waiting to get in to local tune shop to get it dialed) but it's going to need all the help I can give it to keep it cool in the sand turning paddles. I've got an edelbrock water pump, a 160 tstat and a high efficiency 4 core from Jeff's. My question is.... before I buy an aluminum radiator from 1 of the vendors, is there something that guys have found that can be made to fit with more surface? Is an aluminum radiator from 1 of the Bronco supply houses going to make that much difference? I also have the highest cfm electric puller fan from Summit that I could fit in there. I have already cut a fair amount of the core support to fit this set up, so I will further modify if someone has the perfect solution. Thanks for any help.
