Jdgephar
- Sep 25, 2012
- 1,517
I was curious if anyone here had thought about using a heater core in the grill area for some extra cooling capacity. My current setup actually works really well. However, my temperature runs a little bit higher at highway speeds, especially when the outside temperature is 80+ degrees.
The thought is to use something like a van rear heater core. It's only about $14. Route a hose from the bypass at the thermostat housing to the heater core, and return hose to the water pump. Mount it somewhere in the front grill area.
https://www.rockauto.com/en/moreinfo.php?pk=946778&cc=1501894&pt=6864&jsn=1906
Would this be quick and easy extra cooling at highway speeds? It seems too cheap and easy.
I know the explorer system is the preferred solution for anyone with cooling issues, especially at low speeds. I'm just avoiding the cost and conversion...
