- Joined
- Dec 29, 2019
- Messages
- 153
Bought a 96 f250 diesel 4x4 that was hit front & rear (has about 3k miles on engine & trans). Going to try & build a 4 door 1/2 cab bronco.
Got the truck stripped down (the frame is bent in 5 places - the 1st 12" on the front Left & Right sides, left side where the left leaf spring mounts to the frame, & the last 14" Right & Left rear).
Got the front bent back (90% done) want to straighten the left side 1st then finish the front. Going to put a later front & rear axles (with disc brakes & coil front springs) also straight axle in front. Going to install 4" lift springs F&R with 3/4 T front coils & 1/2 ton rear leaf springs. Going to build the body myself starting with the front, as soon as I get to the B pillar of the rear door I can figure the wheel base & shorten the frame. Rich
