If you start talking electric fans the taurus setup I think you would have to mod core support ,,theres the volvo fan option forgot the applications but the motor, blade and mount assembly unbolt from shroud,It's very low profile ,you would have to fab up a shroud to fit radiator and mount fan too,, plus the volvo fan control relay is rather stout..Now with the electric fan this snow balls into the charging system you will need a higher output alternator along with cleaning up wiring,,Then is the explorer front dress another option ??Or test fit your new fan blade when you get it if ok then modify radiator mounts core support to gain another 1/2 inch or so,1 inch min to be safe..
