I have one side done with what sounds like a normal amount of finessing to get all splines lined up, but the passenger side won't line up.
I am putting the stock drum and hub back on but the two locking hub sections will not cleanly line up once inside the drum hub. The inner locking hub section with outer splines will go in, and separately the outer section with inner splines will go, but if they try to line up once together, it won't push . It seems like the axle needs to come up some and I've tried to move it from the u-joint and from the threaded hole but it hardly moves. I have tried to wiggle the drum hub when installing but to no avail. If I spin the drum while pushing the locking assembly in I can get the whole thing in with effort, but the fit is then so tight the hub won't unlock and you have to work like hell to pry the locking hub guts back out.
Damn thing worked when it came off...any ideas or tricks?
Thanks.
Thanks.
