Thanks for the compliments guys! Remember, critiques and criticisms are welcome as well - this is my first attempt at an old vehicle restoration, so I can use all the help I can get
Regarding metal to metal, I am not actually doing any of the body work. I'm just there to do all the grunt work - stripping and sanding and tape and prep. The paint/body guy is doing all that. He actually read from the label to me about how it is easy to sand and called it a complete crock of shit! He only used it on limited areas (the windshield rust holes, a small amount on the pock mocks on the rear quarters, over the welded seam, etc) and I also think he sanded it before it had a chance to fully cure/harden.
Then he used regular filler on all the bad areas. You can see that in one of the last photos I posted above, it's more of a yellow/tan color. He's hoping that after priming we'll only need to use a light glaze for any block sanding. So most of the heavy work was done early. Allen or others with more experience, feel free to chime in if this is not the proper way. Remember I'm doing this on a budget and working within the paint guy's time parameters/etc.
I had the doors, hinges and bolts all sandblasted and etch primed. Also the door latch mechanism and striker blast bead blasted and ready for zinc plating. Anyone have any luck with the
zinc paint from Eastwood? That would be cheaper and easier than sending it to the plater.
Posted a few more photos from today. Sad to say the Bronco won't be making it to the Roundup, but I will be, so hopefully that is enough to keep Tasker happy! Also you can rest easy knowing that my wife and I won't be vying hard for your blind fold driving contest title! Just tonight, in roughly 5 seconds or less, she was able to skillfully guide me to remove the piece of lettuce I had stuck b/w my teeth! Surely this uncanny synchronization would've led to a spectacular result for us
