Fireball05
- Oct 7, 2012
- 1,822
After 2 months of down time, today she roared back to life. I few extra pumps of the accelerator to get some 87 octane up to the right places, a little flick of the key and RUMBLE,RUMBLE,RUMBLE! I know for lots of folks 2 months isn't that long without having your truck run, but it seemed long to me.
The mini-engine bay rewire is complete. The factory wiring that was there was in very good shape, but somewhere along the 37 year lifespan things got added, deleted and changed here and there, so my goal was to tidy everything up. It takes a surprisingly large amount of effort, physical and mental, to sort out the wiring diagrams and then the actual layout and lengths of the wires.
Items completed:
Partial engine rewire, new starter solenoid
Remove radiator, have flushed and cleaned.
Install new radiator hoses and mounts and fan shroud
Remove brand new heater core that was leaking, replace with 2nd new heater core, cross fingers hope it doesn't leak a 2nd time
Relocate overflow tank, regulator and solenoid to OEM locations
Install H4 headlight harness
Install used charcoal cannister
Added new ground wires, from battery terminal to block, body (under the voltage regulator stud and to the frame)
Some Before & Afters:
Not a big fan of the OEM routing (or lack thereof) of the overflow tank tube, so I bent up a tube and then ran hose around up under the fender apron, around the battery and into the radiator. This gets it up out of the way and looks much cleaner. Also will likely get an OEM filter assembly in the future, so should allow room for that.
Battery, regulator and solenoid wiring, with new extra ground wires:
Today I also picked up my front axle from the shop. This turned into a bit more of a rebuild than I was planning, and in the interest of time, since I don't have a press and would've had to pay someone for pressing bearing in and out, etc, I had a shop do reassemble the axle:
New inner and outer seals.
New Dana/Spicer ball joints
New napa premium u-joints
new rebuilt calipers and pads.
Everything else disassembled cleaned and painted.
Now I am actually truly ready to reassemble the front end, and conclude this small 2.5" lift kit install that has somehow magically manifested itself into a 2+ month project ;D
Items completed:
