Firewall wiring grommets
73stallion
Eugene, OR
I had mentioned using these once before, I just thought I'd start a thread with pics of them installed. Application is for a '48 to '59 F100. The reason I like Themis because the grommets on a centech harness sucks and won't stay in the firewall. I just installed these today. Plus there's extra holes in the grommet you can drill to pass extra wiring through if needed.
Part numbers
1A-14603-A for the rubber
https://secure435.hostgator.com/~dl...DIUM/1A-14603-B%20~WLOGO.JPG&i=1A-14603-B&s=0
8A-14608 for the ring
https://secure435.hostgator.com/~dl...ROMMET%20RETAINER%20~WLOGO.JPG&i=8A-14608&s=0
Tuck
Did you have to cut the Centech grommets off? I agree they don't stay in...it's worse when you have the tub lined.
73stallion
73stallion
Eugene, OR
yes you cut off the stock centech grommets. it's real easy to cut them off, just cut into one side and split it. have to do the same to the new grommet to install them.
Thanks for posting up the numbers and pics.
Do you cut larger holes in them for the harnesses, or were the large holes already the correct size for what you needed?
Pestanza
Sunnyvale
The links are dead, any idea where to get something like this nowadays? Same problem ove here, the centech grommets are useless.
Google the part numbers and several sources come up. Sure glad Stallion added the numbers!
The first one, oddly enough is Dennis Carpenter, and their link is dead too! But a couple of the others work.
I still say you should make your own sheet metal panels to cover the stock holes and accept the Centech grommet.
Would look slick I'm sure.
Just sayin'... ;)
Tedster100
Chairman of the Bored
That's what I did because the fiberglass is too thick for most any grommet. If you look closely, there is about 3/4 of a stop sign bolted to the firewall to accept the grommets. The aluminium is perfect, easy to bend, cut and drill and it won't rust. The Centech grommets are also a metric size or something, had to grind the holes a bit to get to the correct diameter after using the closest size hole saw.
jim3326
Appleturkey
Still like these better, IF, for whatever reason, the body has to come off again. Plus they look cool;D
Jim W.
akforsyth
Jim W.
Wow, those are slick, but do they seal to keep water put and prevent corrosion?
jim3326
Appleturkey
Absolutely, they're Mil. Spec. aircraft connectors. Not the cheapest things in the market, but you get what you pay for.
Jim W.
broncoitis
Jim W.
Those are pretty sweet connectors! Any info on them for anyone interested?
dave67fd
They are some of the best in the buisness but only for those who know how to solder and crimp "properly".
You can get them at most of the popular electronic parts distributors.
There are many different versions, styles, materials, configurations etc... available.
Try Mouser Electronics or Digikey to name a couple. My company uses many versions/manuf.. We use alot of the AMP circular connectors which are a much more cost effective solution if they fit your app.
http://www.mouser.com/Connectors/_/N-5g3y/
http://www.mouser.com/Connectors/Circular-Connectors/_/N-76q5a/
jim3326
Appleturkey
Jim
Your such a tease.;D Would you be willing to throw out the part numbers you used and an explanation of how you chose them?
You don't want much, do you?;D;D;D
I might be able to figure out what I got, don't think I still have a receipt. I counted the wires in the harness and separated them by size to figure out which one to get. If I had to do it again I would go with more connectors with fewer wires. Separate it by the system (lights, injectors...etc.). It was a real pain getting them all lined up correctly.
The big one is.... 97-3100A-32-7S & 97-3106-32-7P, small is.... 97-3100-20-14S & 97-3106-20-14P
Then you get to the strain relief housings.
Jim W.
