Firing order for stock 1969 302 V8
Southern California
Im changing the plugs and wires on a recently purchased 1969 EB with original 302 V8
the firing order in place was 1-5-4-2-6-3-7-8
Im new at this so i don't know, but it seems a little strange?
Anyone know the correct firing order?
thanks,
Cora
broncnaz
Thats the correct firing order. Why does it seem strange? Are you used to ch#vys? just be aware that ford numbers there cylinders different #1 -4 is pass side front to rear. 5-8 is drivers side front to rear.
turbotim2
____________
Just for future reference, the firing order is cast into the stock intake manifold if you are still using it.
baddad457
Actually the 15426378 is the same as a Chevy's. The cylinders are just numbered different and I think the SBC distributor spins backwards. Their recent 4-7 cam swap uses the 351W order.
