So I guess my question would be, can I move the injector wiring to match the firing order?
I believe yes, it's that simple.
But it's also something to be very careful of, extending the wire lengths to suit as needed.
Would taking the truck to a tuner and having a chip burned solve these problems?
I believe that yes, that is now also an option.
You can also buy a new computer such as the Stinger Performance which is a Ford EEC housing with a MegaSquirt computer inside. Connects directly to a stock wiring harness, but is tuned to your needs by Stinger initially, but because it's a Mega-Squirt it's also future tunable by you if you want.
In a perfect world we would have swapped the cam before intake install.
I friend ran his this way for a short time, but then decided to go with an Explorer engine and DIS. I have his old motor with only a couple of thousand miles on it and am going to change the cam to an aftermarket unit for better performance, but also with the "351/HO" firing order. So no post-tuning required if I want to go back to factory injection.
But with the state of factory computers these days, I'm probably just going to bite the ($900) bullet and buy the Stinger ECM right off the bat and use it for whatever I need now and down the road. It's upgradable to DIS and even controlling an automatic transmission such as the 4R70w that is so nice to have.
Back to the engine's previous life, it actually ran pretty good when my friend had it. Not perfect though, so you could tell that the sequential injection was on the wrong cylinder. But because the spark was on the correct cylinder it didn't run like crap. Just not quite factory perfect.
