question ;what would be the best wire to splice into for efi fuel pump?
end result will be a fitech efi on a dual tank system. the aux tank will pump into the main (Sherman 23gal) with the low pressure electric pump. the high pressure fuel pump will be in main tank.
has a new centech harness , non efi
I think the l.p. pump is wired on radio . this wont work with the new set up because h.p. pump will run on acc and on key positions. any other ideas fire away.
