I have my command center located on the core support, it's probably 3-4 inches from the radiator generally above where the horn mounts. I can say as far as around town town driving I've never had an issue, but honestly I've been fighting an issue, I thought from the beginning was related to the original vent system in the command center causing vapor lock. It never happened on the street while plenty of fuel was being used. It only happened at times when it was really hot outside and I was driving really slow. My example was repeated many times and only at bronco events. I would be driving in 4 Lo and crawling on the trails and the bronco would just die. I eventually came to the conclusion that the pump was overheating and just would just quit running until it cooled off. At first with the original vent, it would cause the pump to empty the command center when heat built up, but wouldn't let the mechanical pump refill it. After sending the command center back twice, they replaced the fuel pump twice, and replaced the old vent system I still have a problem that persists. Instead of running the command center dry and overheating the pump, it just simply overheats the pump and it quits. It's all heat related I'm sure 100%. It's obvious to me now, but since it runs so good on the highway and around town I've spent quite a lot of time chasing this issue. FITECH support has been great. They helped me when I burned up the first pump on the trail and needed an over the counter replacement. They showed me how to bypass the original vent system. That helped, they've replaced my pumps under warranty and tried to work with me every time I've called. Now for my next attempt at a solution I've hooked up a return system, just using the port on the FITECH throttle body, in my case I have dual tanks, which is one reason I went with the command center in the first place. So I came up with the idea to use the electric fuel change over valve that all the vendors sell. I just used it in reverse and mounted it on the frame. One line coming in from return port from throttle body, one line out to main tank, second line out to aux tank. Hooked the wiring to my factory gauge switch in the dash just like the instructions say. I'm still using my manual change over valve to change tanks for a fuel source, but use the electric switch to change the return destination. So far it works as planned. Haven't got a chance to drive it yet to test it. I have high hopes that this will solve my problems. I could have used a 6 port electric valve that had built in return ports to switch everything electrically, but I kind of like the manual valve.
