Re: PCV—I read that a blocked/bad valve could result in increased pressure and oil being pulled into the engine. Some oil was in a little hole at the end of the block and dropped inside the engine, but not a large amount. That being said, the PCV does rattle as you mentioned in your earlier message so maybe that isn't the issue. But, since it is a $5 part, I don't mind swapping it out and just having ease of mind.
Re: Housing - I plan to get all of that assembled correctly so I am no longer pulling in dirty air. I am also going to get a charcoal canister as well. I've found a used one online (
https://www.northeastclassicfordparts.com/product/fuel-vapor-charcoal-canister-1976-1977-bronco/) at a decent price. That being said, CJ's and some chains sell new canisters; are there any OEM/AMs you'd recommend?
Re: Vaccum Tree—I put new vacuum caps on a few years ago; it doesn't seem like they are leaking yet, but similarly to the PCV, they are not too expensive and easy to replace.
Re: Valve Covers - I was considering switching the valve covers from one side to the other because I have a lot of hoses on the passenger side, and it would help with organization and clutter. I hope to remove the valve covers within the next 48 hours and will provide many photos when done.
Re: Broken Bolt - One thing I haven't mentioned is that one of the manifold bolts broke off (green circle). It looks like a clean break, so I was going to use a bolt extractor to get it out, but I figured I would mention it if you recommend another method.
