Flat towing
Yeller
Rogers County Oklahoma
I actually built a 12' about like that with 7k axle for INPHOBIC to pull behind his box truck. He wanted a utility with sides for general use around the shop/house too. he puts ramps between it and the box truck and puts one inside the truck too, its quite the site to watch LOL
jamesroney
Fremont, CA
24’ total length rv and 14’ trailer fits most every where easy. Have yet to have to unhook to fit a campsite. I’ve considered flat towing, as stated before too many close calls due to uncontrollable mechanical issues so it’s out for me. But if you want to just do it right, remove the driveshaft and have a brake actuator, anything over 2600# it is required equipment. Even with a class 8 chassis coach you still need it.
Many campsites in CA have now started limiting the number of vehicles allowed per site, and the trailer counts as a vehicle. Unfortunately, when you check-in, they issue the parking permit to the truck, and the trailer...so the Bronco doesn't get one. This results in having to park the Bronco on the trailer every night, and you can't drive the Bronco in and out of the campsite. It's really annoying, because they will NOT allow you an extra car permit at any price. The only way to get the permit is to buy TWO campsites. In the old days, it wasn't so bad. Campsites were cheap and available. But with Covid, you can't get a campsite without a reservation. Don't even get me started with the "new reality" that the campsites are all 100%sold out...but are vacant. All of this lunacy is coming to a campsite near you.
Timmy390
Conway, AR
For the record....that's my Samurai on a utility trailer. I do NOT recommend doing that with a Bronco. The Sam weighs 2200 pounds...TOPS......and I only did it for one deer season 180 mile round trip maybe 5 times. The trailer was JUST rated for it.....I might have been pushing it just a bit...... :)
I now flat tow it.......
Tim
Yeller
Most of the time I park the bronco on the trailer just so its out of the way, or if we change our mind to leave its parked all I have to do is throw on the straps. Yes some of the "New Reality" is stooooppppiiiiiidd.
nvrstuk
PNW
California... if your p/u or mtrhome is one vehicle, the trailer you hauled the Bronco in is the second "vehicle" and you can only have TWO "vehicles" then you can't drive the Bronco so it can't be used to go wheeling or even go to the grocery store .... WTH??
jamesroney
Fremont, CA
Well, you can GO to the grocery store, but you can't drive back in past the gate troll without a permit for the Bronco. Since one permit is on the coach, and one is on the trailer...you can see the problem.
6 month online advance reservations only, sold out in 30 seconds. 4 day minimum, Pay in advance. Thursday night and Sunday night are sold out and vacant.
Montoya
I've found a few nice words and offering up some grub can distract even the trolliest of gate trolls.
Also, has anyone tried making a copy of their permit? Just curious if that would work.
bfluegel
Haha, I saw that. It apparently hit 50,000 RPM with the Heep in low range. It probably didn't take many miles for that crank to let go and take the block with it. Tough break for the owner but at least now he can get on the waiting list for the Bronco and be lucky if he gets one in 2022. :cool:
How does that work? First gear and low range holds the Bronco on any incline I've ever driven. Wouldn't the tires skid before the drivetrain turns?
Montoya
I think it completely depends on your coefficient of friction. Kinda like when you put your rig in low range and first gear going down a hill your tires don't just skid and instead you use engine drag to keep at a speed. Imagine that same hill but your being pulled at 60mph.
Honestly there are a lot of questions with this one like, how did you not feel a huge drag pulling a basically locked up heep?
