flat towing an atlas tranfer case
Iambruiser
Forney
Does any one know if when flat towing a bronco with an Atlas Tranfer case do you have to diconnect the rear drive shaft
Nothing Special
The paperwork that came when I bought my Atlas in 2014 says:
The Atlas 2 speed should have at least 500 driving miles on it before you flat-tow, allowing the bearings to break in. If you plan on flat-towing, we actually prefer that you remove the driveshafts from the vehicle. This eliminates any possible chance of bearing failure on your Atlas 2 speed due to lack of oil circulation​
(It also says to never flat-tow the Atlas 4 speed without dropping the driveshaft.)
I've heard that at least some newer Atlas' have an oil pump on the rear output so they may be flat-towed with the rear driveshaft in place. But I don't recall where I heard that so don't trust me on it unless you can verify it elsewhere.
garberz
Bronco Influencer
Conejo Valley, Ca.
Advance Adapters used to advertise that you can fly tow the AtlasII up to 250 miles without removing the rear shaft. I’ve been following this advice for the last 6 years with mine. I do a lot of weekend trips that are close to 200 mi. No issues as of yet. I’ll pull it if I’m traveling more than 200.
Mark
nvrstuk
PNW
On the AA website you can buy an output shaft housing that has an oil pump in it for flat towing.
Spaggyroe
From Advance Adapters website:
We can only recommend flat towing an Atlas 2 Speed (after the 500 mile break-in period) for a maximum distance of 300 miles and then starting up the vehicle and with transmission in gear and Atlas 2 Speed in neutral letting it idle for 5- 10 minutes. If you do not wish to stop and circulate the oil, we actually prefer that you remove the drive shafts from the vehicle.
https://www.advanceadapters.com/knowledgebase/atlas-oil/
I couldn't find anything about an output shaft hosing with an oil pump in it.
Digger556
Yes, disconnecting the driveshaft is best. Without the input turning, there is minimal oil circulation.
The flat-tow rear output has a gerotor pump to circulate oil via the rear shaft.
https://www.advanceadapters.com/tech-vault/6-atlas-tc-tailhousing-options/
nvrstuk
PNW
Flat tow option straight from AA website:
"Flat Tow Tailhousing
Introduced in 2018 the flat tow option was released for the Atlas transfer case. This new option uses a new rear output shaft that is connected to a gerotor pump assyembly. The Atlas pan has a pick up screen that pulls oil from the main case pulling it into the tailhousing and down the output shaft lubricating the bearings while driving and being flat towed. The length of the tailhousing is the same as the standard Atlas. It does not have the mechanical speedometer gear but offers an electronic pick up for a Jeep , GM, or STD which has no pick up."
nvrstuk
PNW
Digger556
Does that rear ebrake rotor clamp hard enough to hold your rig on a STEEP hill or close? What do you use to leverage the caliper? I have talked to so many guys trying to see if it will actually hold and all the guys that use it said they just can't get enough clamping force to hol. Hope yours does and can share.
thanks
nvrstuk
PNW
Digger556
Couple questions OK?
Does that rear ebrake rotor clamp hard enough to hold your rig on a STEEP hill or close? What do you use to leverage the caliper? I have talked to so many guys trying to see if it will actually hold and all the guys that use it said they just can't get enough clamping force to hol. Hope yours does and can share how it's working and how you put that much leverage on a small caliper pad to hold that much weight.
thanks
Spaggyroe
Good info, thanks @nvrstuk. That info lead me to the following part numbers:
P/N AFT-JP Flat Tow tailhousing with Jeep sensor
P/N AFT-GM Flat Tow tailhousing with GM sensor
P/N AFT-STD Flat Tow tailhousing without a speed sensor
Sucks that there's no option for mechanical speedo drive through.
toddz69
Digger556
thanks
I think that photo is probably from a SEMA show booth a few years ago?
Todd Z.
Yeller
Rogers County Oklahoma
Speedhut makes a drive to convert that signal to a mechanical drive. It just snow balls a little LOL
I remember that flat tow option was the newest thing with the Atlas at the last SEMA I went to, so 2018 news.
nvrstuk
PNW
If I remember correctly (and sometimes I do) lol, I was looking at that option but needed the ProCase so that turned into not being an option.
