Flat towing
jamesroney
Fremont, CA
Was yours lifted? Did you flat tow this vehicle? If so, any issues to consider?
Sorry for the delay.
The 1971 Bronco with the Remco was lifted 3.5 suspension, and running an NP435/D20 in the stock location. I flat towed it behind my 1999 F350 SRW PSD crew cab 4x4. No brakes of any kind on the Bronco.
Towed it thousands of miles that way. The only issue is that an Early Bronco is heavy. So you really do need a Brake Buddy...or else you need a lot of weight on the rear axle of your tow rig. Trying to stop on a curvy downhill with an empty pickup truck, and a 4,500 lb suppository on your rear bumper is not safe. That Bronco would push me around quite a bit.
blubuckaroo
Grease Monkey
Ridgefield WA
The one thing I found important is to have the towbar inclined slightly up to the tow vehicle. That can be difficult with a raised Bronco.
The reason this is important is when hard braking, if the towbar is inclined down to the tow vehicle, the Bronco can pole vault right off the hitch ball. If it's inclined up to the tow vehicle, the front of the Bronco is forced down, during hard braking, improving handling.
hucklburry rev2
blknblu69v...
You need to get a copy of the owners manual that came in the glove box.
It recommends disconnecting the rear driveline when towing the Bronco. It makes no difference if your Bronco has an auto or manual tranny.
The problem is the transfer case output shaft doesn't get lubed unless the rest of the transfer case is turning.
When flat towing behind the motorhome, I like to pull the rear driveline completely out and put it in a trash bag in the back. That way if we need to use the Bronco for errands, we can still drive it in front wheel drive.
When we get to the trailhead, the driveline goes back on.
What is going on with a twin sticked D20? If rear in N and front in 4H (really 2H, right?) is the rear output turning at all? I dunno, just a thought. Total removal would be the safest I am sure....
blubuckaroo
Grease Monkey
Ridgefield WA
No matter how you shift any transfer case, the driveline is still gong to spin the output shaft. No problem with most transfer cases.
But... the D20 used on our Broncos is different. The output bearing doesn't lube properly without the input shaft turning.
Nothing Special
Blubuckaroo and I have disagreed on this in other threads before. I'm not saying he's wrong, but here's another perspective. With the tow bar inclined up to the tow vehicle trying to stop the bronco makes it try to lift the back end of the tow vehicle. That give you even worse braking and control over your tow vehicle. I'd prefer to avoid that.
But my real preference it so have the bar level. For a while I had my tow bar angled down quite a bit. The only issue that caused was that when the Bronco (or truck) bounced on its suspension the distance between the truck and bronco had to change as the tow bar angle changed. That resulted in a very obnoxious amount of jerking back and forth in a 3/4 ton crew cab. It was even objectionable in a 28' motorhome! I got a draw bar with enough rise to level the tow bar and it really smoothed things out. And yes, you'd have this same issue if the bar was angled up too much too.
garberz
Bronco Influencer
Conejo Valley, Ca.
I run my tow bar level as well. No ball and hitch coupler either. Mine takes less than 5 mins. to hook up or disconnect, not counting the drive shaft removal. When traveling, most times I’ll just drive in FWD, if we’re just headed to the store or dinner. That’s why I completely remove it, and not just tie it up.
Mark
hucklburry rev2
I didn't ask for that reason - if I were to take the driveshaft off the rear axle and suspend it, for flat towing, then put it in front only with rear in neutral, the driveshaft will spin if driving around? I setup my daughters TJ for flat towing, may flat tow one of the Broncos sometime, I've always intended to take the driveshaft lose from the 9", just curious on driving on the front though, just haven't done it.
72Sport
I understand what you're saying, but why would anyone disregard the recommendation in the owners manual just for the inconvenience of disconnecting the rear of the back driveline?
It was a mental block. After looking at a friends owners manual I didn't see anything of much use. I didn't see anything about how to find missing needle bearings for torn u-joint cups after they were dropped in the dirt etc. I set my D-2 up similar to an atlas. That way I never had to violate my personal rule that I would never take off the rear driveshaft unless it was done at home in the garage. Besides I don't like handling manuals with greasy hands.
blubuckaroo
Grease Monkey
Ridgefield WA
if I were to take the driveshaft off the rear axle and suspend it, for flat towing, then put it in front only with rear in neutral, the driveshaft will spin if driving around? I've always intended to take the driveshaft lose from the 9", just curious on driving on the front though, just haven't done it.
Yes, if your Bronco has a twin stick conversion, you only need to disconnect the driveline from the rear end and suspend it somehow. Make sure you secure it really well.
Also secure the u-joint caps to keep them from falling off.
brewchief
Am I the only one that would consider building a floater rear end and simply unlocking hubs?
Using weld on dana 60 spindles with a 5 lug hub or a weld on adapter and a 5 lug unit bearing hub?
While certainly more expensive then simply pulling the driveline it would probably not be more then a nice purpose built trailer.
Sent from my SM-T510 using Tapatalk
jamesroney
Fremont, CA
Uhm, yeah...You are on your own. Unlocking hubs are not adequate for the rear of a Bronco. I have had pretty much every unlock hub kit that has been sold...and they all suck. From the 6 bolt external bolt Jeep hubs on the back of my CJ-2A to the Warn 30 spline small hubs, to the Warn 35 spline big hubs. They just can't handle the load...and you end up putting in drive slugs...which defeats the purpose.
They also stick out and get killed by rocks. Funny thing is that they stick out the same as the front...but for some reason, the rears get dragged across the rocks more.
Turns out if you lock the FRONT hubs while flat towing the Dana 20...the low range drive gear will sling oil up to the tail shaft bearings. But it won't lubricate the pocket bearing on the input side.
All in all, I still think Remco is the way to go.
blubuckaroo
Grease Monkey
Ridgefield WA
I really don't get this dilemma. You want to be seen as a rugged four wheeler. Yet you resist the simplest mechanical job. God help you on a trail!
Maybe someone needs to make a Utube tutorial on disconnecting a driveline.
72Sport
Changing out the stock fill plug with a hex nipple, a 90 degree elbow, a second 90 degree elbow moving the fill plug to the top elbow adds about 2" to the depth of the oil in the d-20. The new level of oil keeps everything well lubed. The oil in the cavity between the two bearings then fills up with oil also. If you remove the front housing from the front of the d-20 and install a plexiglass window you can see what is going on when you run the transfer case with a drill motor on the output shaft. You do need to use Torco or equivalent 50 wt racing oil to the case so the oil doesn't foam. A remote vent in the stock position will take care of the venting problem.
I believe the additional oil constantly lubes the 13 needle bearings and about everything else.
jamesroney
Fremont, CA
I would love to see that video...especially where someone removes only one end of the driveshaft, and then tries to move the Bronco with the driveshaft whipping under the truck.
Or the guy who has to get under his Bronco at the gas station / RV park / cul-de-sac and has to roll around in the snow/mud/cow-shit looking for the little needle bearings that fell out.
Or the guy that pulls his rig into the campsite, late, tired, and in the dark and leaves his tow rig idling for 20 minutes while he installs his driveshaft so that he can de-couple his Bronco and his kids don't freeze in the truck.
Or the guy that wakes me up in the morning asking if I have an extra 1310 u-joint strap because the one's he left in the yoke disappeared.
Or the guy that burnt up his transmission because he left his front hubs locked, because he's been driving in Front Wheel Drive since the last hotel stop where he had to uncouple...and didn't want to crawl under the Bronco.
That's going to be a great video...
Nothing Special
I did that on my old '75 CJ5. It's not a bad option, but it has its downsides.
Yes it was really easy to get it ready to tow, or ready to drive. That was really sweet and was why I went with a full-float conversion.
But it adds some slop to the driveline. When added to the slop that was already there from the Detroit I had in my Jeep it was pretty noticeable. And it magnified the handling quirks of the Detroit. With an automatic trans and any diff other than an automatic locker it wouldn't be as bad.
It also introduces a weak link in the rear axle.
And you can run into trouble with leaking gear lube. On my Jeep the kit I used had seals in the ends of the axle tubes that kept the gear lube in the tubes, and I greased the wheel bearings like you do front wheel bearings. But "they" recommend not having seals there so the rear end lube will lube the rear wheel bearings. But then the locking hubs tens to leak lube. So is the setup I had best? It worked for me, but I could certainly imagine losing those seals pretty fast since the axle isn't as well located there (in a front axle the seals are in the diff housing where the axles can't hardly move at all).
With all of those down sides I still was going to go the same route on my Bronco. But I couldn't find a kit, and I didn't have the time or energy to piece it together myself, so I haven't done it, at least yet.
By the way, another advantage to a full floater being able to drive it off the trail and still flat-tow it home with a broken rear axle.
Nothing Special
That's why I take the extra couple of minutes to take out the four bolts that hold the front of the driveshaft in and remove the shaft entirely.
Yeah, you want to be careful with the caps. Another reason to remove the driveshaft entirely rather than leave it bouncing around under the vehicle.
Pull the 'shaft all the way out and all you need to do it lock the front hubs and shift the t.case into 4WD. That doesn't even take 20 seconds.
Yeah, don't leave the U-bolts in the yoke. Bring a zip-lock bag or something and put all of the hardware in the vehicle with the driveshaft.
Why would driving in front wheel drive burn up your transmission?
garberz
Bronco Influencer
Conejo Valley, Ca.
If you just remove the rear shaft completely, it doesn’t cause any of these issues. %) With the rear shaft out, I can drive wherever I want in FWD and still have a 5 min hook up in the morning when I leave the RV park. Forgetting to unlock the hubs won’t cause any damage to the trans. The T/C needs to be in neutral, or you’re not moving anywhere with the trans in park.
Mark
Nothing Special
.... Forgetting to unlock the hubs won’t cause any damage to the trans. The T/C needs to be in neutral, or you’re not moving anywhere with the trans in park.
Mark
I leave my t.case in 4WD high and my manual trans in 1st when I flat tow. That way I KNOW if I forgot to unlock the front hubs.
