flex plate differences
BroncoBrad
Athens
In the process of starting my rebuilt 302 to break it in. I am changing from a 3 speed manual to C4 automatic. When we crank the engine there is a noise that the engine builder believes could be the flexplate. Called Bronco Graveyard where I bought the flexplate and they said that the flexplate they carry is for certain years (can't remember which). I don't know the exact year the tranny is out of, but I know it is an early Bronco. Can anyone shed some light on what the differences are between the flexplates? Does the flexplate change tied to the year of the engine, or the transmission?
tasker
all knowing of nothing
NH
28 or 50 oz balance....need to make sure you get one fir a c4 and not c6...ask me how I know!!
Eoth
Both the 28oz and 50oz will fit and idle just fine (pre-1981 you want a 28oz. imbalance, if '81 or newer you want 50oz). You wont know you have the wrong one until you go for a drive.... Don't ask ME why I know that.....
I did run into a situation where a lock nut (securing the inspection plate I believe) was too big and was getting hit by one of the balance weights on the plate.
Hotrodjohn
164 tooth and either 10.5 or 11 3/8 bolt pattern for converter. Dont know how it would hit unless wrong starter as mentioned above. The main differences in 73 to 77 C4 flex plate was some had 10.5 small converters and most had 11 3/8 but that wouldn't be your problem if you have it bolted up.
Mikesimp70
Flexplate is specific to the C4 or C6. Difference is offset.
Looking back in my notes you want the Pioneer #FRA205 or equalivelant
B
BroncoBrad
Athens
Please excuse my ignorance, but the 28 or 50 imbalance, is that referring to the flexplate, the converter, or the engine?
I bought a high torque gear reduction starter from Wild Horses because I am running headers. It seems to crank fine and there are no signs of damage to the starter upon inspection.
I plan to pull the tranny when I get a chance so I can check the flexplate for damage. Any other words of wisdom or suggestions?
Eoth
Imbalance references are for the flexplate. Mikesimp70 provided you a part number for a 28oz flexplate for a c4 transmission that would be found in a "stock early bronco" that has a 302.
You did put the block plate between the engine and the transmission, right?
That is precision stamped and locates the starter off the dowel pins that also align the transmission to the block. So just confirm that you have both dowel pins in place and the block plate. If not the starter isn't going to be correctly aligned to the flexplate.
garberz
Bronco Influencer
Conejo Valley, Ca.
This^^
And the block plate is different when using an auto trans. The lower section uses an inspection plate that gives you access to the torque converter nuts.
Mark
All of the above.
Obviously for this discussion we're talking about flexplates/flywheels, but the imbalance factor starts with the engine's crankshaft. This is a weight factor that needs the three pieces involved to match. The crank can't be balanced without the proper damper and flywheel in place.
In earlier 302's and ALL 351 Windsors, the crank imbalance was the 28oz mentioned (something like 28.8 but it's been rounded off), so you need a crank damper and flywheel that have the proper weight to match the crank.
Same goes for after they changed to the different weighting of the crank on later 302/5.0 engines (50.2 oz I think?), you have to have the correct damper and flywheel/flexplate.
So it's not a question of which transmission is used. It's all about the engine and those three components. Get one of them mismatched, and your engine will shake like a big dog at anything above 1200 rpm or so.
The changes in flexplate between one trans and the other are other aspects (such as the offset mentioned) but have nothing to do with the imbalance.
The 157 vs 164 tooth larger and smaller changes are vehicle/bell housing specific and also do not have anything to do with the balance. Both imbalances are available in both tooth counts.
And even though you probably already know this part, the starters for our engines are decided by whether the transmission is an auto and manual.
What is the noise that it's making exactly? Can you describe it?
When you're under there messing about and rotating the engine to loosen the nuts, make sure to keep an eye on different things to make sure there is no interference anywhere.
Verify that your torque converter is seated all the way into the transmission.
Was it a high-pitched whining sound? Might be your transmission's oil pump.
Did the transmission seat all the way to the engine block without any trouble? Or did you have to pull it in with bolts? That latter would be a bad idea with just about any engine, but more so with an auto. Might mean that the torque converter has a different offset than the flexplate can mate up with.
Since you got it bolted on, it's a good bet that at least the bolt patterns matched, but if the offsets were different, you could have pressure between everything.
Good luck.
brewchief
Did you buy new bolts with the flexplate? The flexplate is thinner and takes a shorter bolt, it's possible for the long bolts used with a flywheel to contact the rear main cap/block if used with a flexplate IIRC.
B
BroncoBrad
Athens
Thanks for all of the suggestions. I'm going to put the old starter back on and crank it over to see if it could be the new starter causing the noise. If I can eliminate the starter or starter bolts as the culprit, I will go ahead and pull the transmission off and check the new flexplate for issues.
After talking to my mechanic, I have the correct flexplate, used new bolts and torqued it to specs. I have the correct blockplate and pins are present.
DirtDonk, I did not know that the starters are different for manual or automatic transmissions. Is that starter available for both transmissions?
Yep, both styles, both applications.
It's not just an aftermarket thing, since the factory changed over to a PMGR (permanent magnet, gear reduction), or "mini" starter years ago too.
Usually, the two starters will bolt up to the incorrect trans application, but the gear will not engage properly, or engage at all.
There are diagrams showing the difference in gear position when static you can use to compare what you have to what you should have. I'll see if I can find one.
What's too big? The bearing end cap too deep and bottoms out on the bell housing? Since the auto starter is the deeper one, that would make sense at least. But the manual version not fitting the auto, is it the register diameter won't let it fit into the hole?
If that's the case, then I that might explain how I got an auto starter in my manual bell housing. Never tried the manual in an auto, but had heard of other issues with engagement, so at least some of the people are making it into the hole.
Maybe they're leaving the block plate off? Seen that happen many times.
Other than that, they're the same bolt pattern, same size and shape externally. Interesting.
Sounds like all the "wrong starter in the hole" stories must be about auto starters in the manual bell housings.
You still coming up to the Roundup so we can set them side by side and check it out? Looks like we're going to have great weather in spite of the rain fears. Going to be mostly in the more coastal cities and the rain's gonna' get mostly scraped off by the mountains before it gets to the valley.
See you there.
garberz
Bronco Influencer
Conejo Valley, Ca.
What's too big? ....the manual version not fitting the auto, is it the register diameter won't let it fit into the hole?
Paul, that’s been my experience. The register diameter is just a bit bigger on those manual starters. The old auto starters are the same register diameters as all the newer stuff. I believe auto and manual became the same size at some point.
I’ll see you at the Roundup!
Mark
