tirewater
When installing the transmission, how do you make sure that the TC doesn't disengage from the pump when pulling it forward onto the flexplate? (this is when the bell housing is already mounted against the engine block)
TCI states that you should have 1 1/8" inch between the bell housing edge and the torque converter pad where the flexplate mounts. The measurement is suppose to let you know when the pump is fully engaged by the torque converter.
What's the corresponding measurement between the block face and flexplate surface where the TC mounts?
Or, what's the measurement between the torque converter's pads where the flexplate sits and the flexplate when the torque converter is all the way pushed into the bell housing?
Since I just spun my oil pump bushing using a new flexplate & torque converter, I'd like to eliminate the possibility that the flexplate is too far away from the torque converter - causing the TC to pull forward too far.
Thanks!
Chris
Thanks!
Chris
