Fluids???????
broncoitis
Gotta fill up the diffs and Transfer Case and thought I would do that today or tomorrow. What do you guys recommend using in the diffs and transfer case.
Thanks!!!!
Same here. I just chose a slightly different mix is all. Using Redline 75w/90 synthetic.
Just a slight variation on the same thing.
Regarding the transfer case though, you have to choose a gear lube specifically without the additives that don't play nice with the bronze bushings and thrust-washers.
Don't quote me, but I think it's the GL-3 and GL-4 rated products that you want to avoid.
I might be wrong with regard to the ratings, but you do have to watch out for those things. I think you're safe with most synthetics though.
I have some info saved, but rarely am able to find it quickly when I need it. So don't hold your breath, but I'll try to find it.
