- Jun 11, 2004
- 11,871
Also, I have read several threads about the ears of the slip shaft being "in phase" with the forward side. Many have said that this isn't necessary with the CV joint? Is this wrong? If it is wrong, then I very well could have it messed up. I did, just for giggles, line up the back end up the way you are supposed to with the old non-cv joint shafts. But, I could be 180* off.
Technically, it should not matter what the "phasing" is between the double cardan (a "CV" setup) and the pinion joint; that said, I've had a couple driveshafts that had a pesky vibration at certain speeds and it did change for better and worse by playing around with the phasing. Hit or miss though.....
